Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Product Reviews
Product Reviews Have you found a great product, or a really bad one and you just need to tell someone about it! Post up a review for the benefit of all!
Old 02-14-2011, 07:30 PM
AddictedSC AddictedSC is offline
Vehicle: 2011 Ram 1500 Laramie Crew Cab
Trim Level: Laramie 4x4
Rep:13
AddictedSC is on a distinguished road
I had one on my Toyota and it was awesome. I just picked up my Ram, but this is a definite addition for my new truck. It is super easy to install, took less than 10 minutes with my 8 year old helping. Also, it looks as good as my truck still almost 3 years later. Great investment for your truck and you loose so little space when it is open to haul stuff.
Old 02-14-2011, 10:22 PM
TALLA's Avatar
TALLA TALLA is offline
Vehicle: 2008 1500 Dodge Ram Quad Cab
Trim Level: RAM 1500 Big Horn
Rep:56
TALLA will become famous soon enough
Send a message via MSN to TALLA
looking at some thing like that to but cant make up my mind on what to get power one normal one
2006 Chrysler 300C 5.7 Hemi
2008 Dodge Ram 1500 Quad Cab Big Horn 5.7 Hemi
Old 05-06-2011, 11:29 AM
dcaylor dcaylor is offline
Vehicle: Dodge Ram
dcaylor is on a distinguished road
Now that you have had the bak flip for a while, do you still like it? Did you consider the rollbac version? I'm looking for a cover and can't decided which is best. Any help is appreciated.
Old 05-17-2011, 10:42 AM
09ChallengerDad 09ChallengerDad is offline
Vehicle: 2011 RAM 1500
Trim Level: Laramie 4X4 Quad Cab
09ChallengerDad is on a distinguished road
We got the F1 BakFlip a few weeks ago. I went back & forth with Morrey at BakFactory Outlet, trying to find out if the F1 could be mounted without removing or modifying the bedrails on our '11 Laramie. Bak said I could mount the F1 without an issues by leaving the OEM bedrails in place. ........ Not quite.
I did have to modify the rear bedrail mounts (the black plastic bases that slip into the stake pockets) by trimming a groove of 1/4" high by 1/2" wide (with a utility knife) to allow the BakFlip mounting rails to fit under the bedrail bases and flush against the bed while maintaining the spacing between them all of the way to the tailgate (keeping the rails parallel). The BakFlip mounting rails cleared the front bedrail mounts with no problem, but not the rear, so they had to be trimmed before installation. That added about 15 minutes to the installation, which I did myself in about an hour. I ran the drain tubes through the plugs in the front of the box.
I've had the F1 on for about three weeks now, and it stays pretty dry inside. I'm assuming it will be waterproof when the rubber seals settle with some time and sunlight (which has been a rare commodity here this spring). The nicest part of the F1 is that I can lock items in the bed - under the F1, and not worry about anyone stealing anything when I leave the truck unattended.
It's better than a soft cover (more secure, and allows much quicker access to the bed), and much more convenient than a cap or hard tonneau.
Old 05-17-2011, 11:11 AM
Zac2109's Avatar
Zac2109 Zac2109 is offline
Vehicle: 2011 RAM 2500
Rep:56
Zac2109 will become famous soon enough
wow that looks pretty nice, I dont usually like bed covers, but the way it sits flush in the bed would be a big selling point for me.
2011 RAM 2500 6.7L Cummins, 1968 Ford Mustang Coupe 289 V8
Old 05-21-2011, 05:02 AM
rambilt rambilt is offline
Vehicle: 2005 Dodge Ram 2500
Trim Level: XT
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
rambilt is on a distinguished road
Default Backflip G2
I had mine installed yesterday. It cost me 919.00 out the door with free lockable tailgate latch. My only complaint is, it's not 100 percent waterproof. It was raining when I got home from the place I bought it from, open up the tailgate and there was water leakage in the front corners. Not much but got the corners wet. No biggy for me because I bought if for somewhat secured storage. Other than that minor water leak I love the fact that it's flat, looked good and my truck bed is not limited to carrying groceries from Walmart... BTW it's on 05 2500 RAM QC..
Old 12-21-2011, 09:28 PM
Nickster's Avatar
Nickster Nickster is offline
Vehicle: 2003 Ram 2500 cummins
Trim Level: Slt
Color: Blue
Nickster is on a distinguished road
Great review, I have the same cover and love it!
I'd rather be cummin then strokin
Old 12-21-2011, 09:30 PM
Nickster's Avatar
Trim Level: Slt
Color: Blue
Rambilt,
Did you notice if they put the drain tubes on the front of your cover. Mine has a tube in each corner up front to drain the water out.
Old 12-23-2011, 10:08 PM
Almond 04's Avatar
Almond 04 Almond 04 is offline
Vehicle: 2010 Ram 1500
Trim Level: Big Horn SLT
Color: Austin Tan Pearl
Rep:30
Almond 04 is on a distinguished road
Very very nice. I am in the market for a cover soon and a tri fold cover is deffantily what I want. Looks great!
Cabin A/F mod / Mopar CAI / 390hp hood spears / Extang Trifecta / Custom Badges / Interior-Exterior LED's / Painted eng cover
Old 12-25-2011, 11:35 AM
MartinJD's Avatar
MartinJD MartinJD is offline
Vehicle: 2011 Dodge RAM
Rep:14
MartinJD is on a distinguished road
Just a heads up on the drain tubes: Mine fell off twice so I used some silicone to secure them for good.
