Outside temp sensor stuck - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 12-24-2009, 02:47 PM
Dodgem's Avatar
Dodgem Dodgem is offline
Vehicle: 05 4.7L 1500 2WD
Trim Level: Quadcab
Dodgem is on a distinguished road
Send a message via Yahoo to Dodgem
Default Outside temp sensor stuck
Both on the overhead display:
Mpg keeps resetting, starting at 0.0
Outside temp sensor stuck on one number
Any idea how to fix this?
k&n drop in, airraid intake tube, nerf bars, bosch plat single grd, fiberglass cover, 90k
Old 12-24-2009, 03:12 PM
That may take a dealer flash to reset it. I don't think you can do it with the user controls. Have you cycled through all the options you have and tried to reset them???
Old 12-24-2009, 03:28 PM
Resident Technician
Rep:1915
TSB 08-026-06 REV A addresses this issue.
SUBJECT:
Flash: Overhead Console Temperature Reading Inaccurate Or Dome Lamp Turns Off Too
Soon
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Cabin Compartment
Node (CCN) with new software.
MODELS:
2006 (DR/DH/D1) Ram Truck
NOTE: This bulletin applies to vehicles built on or before May 30, 2006 (MDH
0530XX).
SYMPTOM/CONDITION:
The vehicle operator may notice that if a vehicle door is left open for longer than 20
seconds the illuminated interior (dome) lamps will turn off.
The vehicle operator may describe that the ambient temperature first displayed in the
overhead console is not accurate (displays -40C or -40F), when the ignition switch is
turned to the “On” position, then slowly updates to the outside ambient temperature as the
vehicle is driven.
Old 12-24-2009, 04:04 PM
So, a flash is needed.
All Right! I got one right! 1 outta 10 ain't bad...LMAO
Old 12-24-2009, 05:41 PM
Resident Technician
Rep:1915
Gotta start somewhere, right MD?
Old 12-24-2009, 06:13 PM
nawwww...I don't start anywhere in particular...I just fumble around...
Old 12-27-2009, 03:25 PM
Dodgem's Avatar
Trim Level: Quadcab
Thanks, so this is a dealership problem for them to fix?
What's a flash?
Is there anything that I can do?
Yes i did go through all of the settings an reset them all. I even thought about disconnecting the battery for a hard resett. And would the location of the temp sensor be located in front between the grill and the radiator? Wouldnt the sensor itself be bad?
Old 12-27-2009, 04:04 PM
Resident Technician
Rep:1915
A flash is a reprogramming of the related module with updated software and needs to be done by the dealer. The sensor is located near the left headlight and, yes, it could be bad.
Old 12-27-2009, 07:44 PM
Dodgem's Avatar
Trim Level: Quadcab
Thanks Rem
Old 02-01-2010, 04:13 PM
Dodgem's Avatar
Trim Level: Quadcab
My overhead temp console was stuck or frozen on 130 F. I disconnected the battery for a second and reconnected wala.........the overhead is back to normal. Good old "hard reset"
