Old 12-26-2009, 10:38 AM
diesel04 diesel04 is offline
diesel04 is on a distinguished road
Default 02 2500 levelling kit
Hey guys, new to the site. I got an 02 club cab shorty 4x4 cummins. just put 5100 bilsteins and 2'' coil sopacer kit in my truck from topguncustomz.com. ive noticed a hard clunk from the front end when i hit pothols and such. shocks also ride a little stiffer than stock, which i dont like, will this change after wearing them in?. main question is what could cause the clucking, could the springs be sliding around on the spacer? replaced swap bar end links already so that not the problem.
Old 12-26-2009, 11:27 AM
Yeah, I've never liked spacers so that could be the problem. One thing to check is to make sure all mechanical connections are at the proper torque spec.
Welcome to the forum! Please go to your User CP and Edit your Details to add your truck info. That will help us help you when you have a question.
Old 12-30-2009, 08:52 AM
HOYD HOYD is offline
Vehicle: 2004 Dodge Ram 2500
Trim Level: Larimie Sport
HOYD is on a distinguished road
I had this problem after lifting my titan and it ended up being the struts were to short. I see you bought the 5100's, did you buy factory size or an 1" or 2 bigger? That might be one of the issues, but it may also be improper install. Sorry I cannot be of more help, but I cant see it LOL.
Kyle
