What is the widest tire? - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 01-11-2010, 02:34 PM
smartel's Avatar
smartel smartel is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Crew/Sport w/HEMI
Rep:47
smartel is on a distinguished road
285/50/20's look really good on those trucks. wider and a little lower profile. I had the Goodyear Eagle's on my 05 QC and they hooked up pretty well.
09 Crew Cab Sport, HEMI, Line-X spray in liner, 4.10's with limited slip, Diablosport Predator, K&N Filter, Mufflex/Magnaflow 24" muffler--best 1/4 mile 14.200 @ 95.76 mph (with 4.10's and no tuner)---Modding is far from complete!
Old 01-11-2010, 06:10 PM
57Hemi08's Avatar
57Hemi08 57Hemi08 is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT Big Horn
Rep:42
57Hemi08 is on a distinguished road
If you have 275/60R20 stock the widest you can go is 12.25" without rubbing. You can go 12.5" if you put a 1/4" spacer on the front. The back you can go 12.5" without a spacer. Metric size you should be able to run 305.
Old 01-19-2010, 10:24 PM
blundon85 blundon85 is offline
Vehicle: 2007 dodge ram sport 4x4
Trim Level: sport
blundon85 is on a distinguished road
Send a message via MSN to blundon85
i think the dodge will accept a 315 and if you wanna go wider you can get wheel spacers
Old 06-03-2010, 10:42 PM
sport14692's Avatar
sport14692 sport14692 is offline
Vehicle: 2011 Dodge Ram
Rep:42
sport14692 is on a distinguished road
Send a message via Yahoo to sport14692
So what are the results?
Sport14692 OUT !!!
Old 06-04-2010, 10:05 AM
Wrkinprogress's Avatar
Wrkinprogress Wrkinprogress is offline
Vehicle: 2005 Dodge Ram 1500
Color: Charcoal
Wrkinprogress is on a distinguished road
I'm running 325/60/20 Khumo AT's on my stock 20's with a leveling kit, only time they rub is in full steering lock.
Old 06-04-2010, 10:44 AM
chefred112's Avatar
Rep:656
widest I've run was 285/50's...
Old 06-04-2010, 03:15 PM
Color: Charcoal
Here's a pic of the 325's
Old 06-04-2010, 11:43 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Ok so i have seen a few misleading posts!! first all a 305/55/20 is just over 33" tall and 12.4" wide...not 13.5" wide!!!!
I have 325 on my truck, its about 12.8" wide, but they are 35's so they have enough side wall!!
You sound like your more performance oriented so i would probably say 305 or 12.50 is the widest you want to go because your probably not lifting/leveling the truck for mor clearance! you could probably get away with a 315 on the rear, thats where you want the traction, then if you want to keep the stock size get a 305/55/20, same diameter just wider!! Chefred has his ram set up for drag N/A he said he is running a 285/50, i would say if you plan on lowering it an to be more drag oriented thats probably closer to a size u want, lower profile!! its hard to tell what your other plans are with the truck!! so there is quite a few suggestions in there
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
