Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 12-27-2009, 03:59 PM
crazy5269 crazy5269 is offline
crazy5269 is on a distinguished road
i dont know how to tell if it is or not
Old 12-27-2009, 04:05 PM
Rep:1909
Are you sure you're talking about the blend door and not the recirc door?
Old 12-27-2009, 04:12 PM
the blend door is connected to the little motor on the underside of the unit correct and the recirc door is the one behind the glove box door to the right up a little right
Old 12-27-2009, 04:20 PM
Rep:1909
Yeah. You said you can actually move the blend door but get no temp change and can touch the core and it's hot? You need to pull the blower and check for debris.
Old 12-27-2009, 04:32 PM
but im still getting the same amount of airflow from the vents on either way with the blend door
Old 12-27-2009, 04:37 PM
Rep:1909
And you've actually removed the actuator and moved the door by hand?
Old 12-27-2009, 04:44 PM
yes i have i get heat for like a second then it blows cool
Old 12-27-2009, 04:46 PM
Rep:1909
That's a bit different than NO heat at all. That sounds more like a circulation or core problem.
Old 12-27-2009, 04:48 PM
why would it blow warm for a second then blow cool the airflow amount doent seem to change
Old 12-27-2009, 04:50 PM
Rep:1909
Insufficient flow would take all of the heat out of the coolant that's in the core in a matter of seconds.
