Old 12-27-2009, 09:13 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default Service 4wd light on new 2010 Sport
Picked up a new 2010 Sport with the 5 position transfer case tried shifting into 4 Auto and the service 4wd light came on, pulled over shut it off, started up tried it again and it worked, and for several more times it worked. I let the truck sit over night same thing the next day, any ideas?
Old 12-28-2009, 12:19 AM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
I'm far from a pro, but in my personal experience, most of these warning light issues are simply sensors acting up or malfunctioning.
In the "good old days" when trucks came without all these sensors you would only be aware of trouble if there actually WAS a problem. If you are hearing a funny noise or feeling something, then there might be a real issue. Otherwise, I bet its some kind of sensor being overly "helpful". I had a sensor issue with my 2010 sport. Mechanically, my truck was perfect, but the "check engine" light was on and required some kind of sensor replacement.
I know thats not a very technical explanation, but hey, Im not a very technical guy!
Ambitious, but rubbish!
Old 12-28-2009, 07:12 AM
Uncle Buck's Avatar
Uncle Buck Uncle Buck is offline
Vehicle: 2010 RAM 1500
Trim Level: SLT 4X4
Color: Brilliant Black Crystal Pearl.
Rep:16
Uncle Buck is on a distinguished road
I agree with Greg .... more than likely a sensor issue. We engineers tend to apply them like cheese on pizza ... you can never have too many !
Old 12-28-2009, 07:32 AM
Rep:1890
Could also be an actuator issue. Let the dealer fix it.
Old 12-28-2009, 08:33 AM
What he ^^^^ said. Get Thee To The Dealer.
Old 12-28-2009, 08:50 AM
Sounds like a trip to the dealership .
Old 01-24-2010, 01:34 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
It's wierd, now that you said that. On friday I had a new 2009 ram with a Service 4WD light on. Ended up being the final drive control module. It had a trouble code for an internal fault. I replaced it under warranty.
Old 01-24-2010, 02:06 PM
Vehicle: SRT-10
Rep:434
Mine turned out to be the the drive train control module, it was replaced this past Tuesday and its worked every time hot or cold since, where as before it would never go in on the first attempt when it was cold but usually did when it was warmed up.
Old 01-24-2010, 08:08 PM
Cormacs's Avatar
Rep:14
I wonder if this will be a common problem.
Old 01-27-2010, 02:11 PM
Gigantle's Avatar
Gigantle Gigantle is offline
Vehicle: 2010 Laramie
Gigantle is on a distinguished road
I have the same problem with my 2010 Laramie. I have an appt this Friday and will post the resolution. Hopefully it is just a sensor.
