Old 12-13-2010, 08:12 PM
pieece's Avatar
pieece pieece is offline
Vehicle: 03 Dodge Ram 1500 QC 4X4 5.7H
Color: Two Tone - Grey/Silver
Rep:38
pieece is on a distinguished road
Originally Posted by ccga3359 View Post
Only if someone was asllep at the switch on the assembly line!
The gear ratios are the same that way all four wheels turn at the same speed. A 4x4 has two differentials, an AWD has three. Each axle has a diff, this allows one wheel to turn at a different speed to the other wheel on that axle. In the simplest form only one wheel is powered, the other wheel is along for the ride. Tends to be the wheel with less traction gets the power hence why a 5 litre Mustang just sits and spins and goes backwards down a snowy hill that he's trying to get up. So in the 4x4 Ram we split that power front and back through the transfer case that way we're powering one wheel in the front and one wheel in the back. In an AWD their transfer case is basically a differential cending power either to the back axle or front. AWD do use an certain amount of hocus pocus to devide the power otherwise you'd just have a higher, boxier Mustang spining one wheel either in the front or back. 4x4 guys can further power all their wheels at the same time by using locking differentials, so that both wheels on the same axle are locked together like the transfer case does for the front and back.
Now the reason for your symptons on tight turns is because all four wheels are following a different circle, therefore all 4 wheels need to turn at different speeds. Going forwards 4x4's are fine because all four wheels are travelling the same distance at the same speed, sloppy or dry it's fine just uses more gas because the engine is working harder to power the front diff. In tight turns, with two power wheel locked to gether something has to give. Sloppy conditions like snow or wet mud allow the front wheel to slip therfore letting it speed up to match the speed of the rear wheel. On dry pavement it doesn't slip (at least not easily) and that's what you're feeling, pushing the front tire to the point of maximum traction, letting it lose traction only to find traction again, then only to lose traction. Very hard on the tires, very hard on the drivetrain. So yes slip it back into rwd on tight turn on dry pavement.
^----Me left
ccga - Right
Guess I stand corrected.
Now I'm going to go do some research.
17" Eagle Rims/2" Leveling Kit/33" Nitto Terra Grapplers/Billet Grille/K&N CAI/SUPERCHIP/-5% Tint/Black Chrome Running Boards/Black Chrome Light Bar/Behind the Grille Running lights - HALOS/4 100W KC Daylighters - Black/Fire-Ice Bar/Recon Smoked LED Cab Lights/Electronic Safe/
Old 12-13-2010, 08:16 PM
ccga3359 ccga3359 is offline
Vehicle: 2005 Dodge Ram 1500
Color: Atlantic Blue
Rep:42
ccga3359 is on a distinguished road
Originally Posted by pieece View Post
^----Me left
ccga - Right
And I could yet stand to be corrected too. For me from the tranmission back is a lot of black magic. Rep to you for not getting into a flame war.
Grant
No matter how much you push the envelope, it's still stationary.
Old 12-13-2010, 08:24 PM
pieece's Avatar
Rep:38
No reason for a flame war.... If I'm wrong then I'm wrong. lol
But When I grew up I have always known gear ratios in the front to be a little off set then the rear... ? Or am I wrong there.... I'm researching it right now though. haha
Old 12-13-2010, 10:28 PM
95dodgeV10's Avatar
95dodgeV10 95dodgeV10 is offline
Vehicle: 1995 dodge ram 2500
Trim Level: Laramie SLT
Rep:24
95dodgeV10 is on a distinguished road
i have heard of the front ratio being slightly different allowing the front to essentially pull the rear keep it from sliding around in slippery conditions. i don't have any proof of this but that's why you're not supposed to run 4x4 on dry pavement at all cause it sort of tensions the drive-train and causes excess wear on the tires and differentials even in straight lines
Old 12-13-2010, 10:44 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
What he said. Called driveline bind. No bueno on dry pavement in a cornering situation.
2004 Dodge Ram 2500 4X4 5.7
Old 12-14-2010, 08:04 PM
okami89's Avatar
okami89 okami89 is offline
Vehicle: 02 Ram 1500 SLT
Color: Fire Red
Rep:26
okami89 is on a distinguished road
Yeah it's normal it does that so that in mud and other wet spots it will dig in and give you traction, you won't feel it in wet surfaces.
Aut Pax Aut Bellum
- Clan Gunn
Old 12-16-2010, 04:31 AM
FingerBang's Avatar
FingerBang FingerBang is offline
Vehicle: 2009 Dodge Ram 4x4 QC
FingerBang is on a distinguished road
owners and/or service manuals right from dodge and free.
http://www.dodge.com/en/owners/manuals/index.html
RC 6" Suspension Lift --Black KMC SPY 17x9 (-12mm offset 4.53 BS)--- Nokian Vatiiva M/T 35x12.5R17
Old 12-18-2010, 08:47 PM
Houwlin Houwlin is offline
Vehicle: 2005 Dodge Ram QC 1500 4x4
Color: Grey
Houwlin is on a distinguished road
Thanks for the link. I keep a laptop in the garage just for this reason.
Old 12-26-2010, 09:58 PM
MRP's Avatar
MRP MRP is offline
Vehicle: 2010 RAM Sport 4x4
MRP is on a distinguished road
Don't burn your hubs bud - Use 4 low, not 4 lock.
Toms River NJ
Leveling Kit, Power Chip (Diablo), Ridiculous Audio System, Custom Headlights w/ Leds
Old 12-31-2010, 09:41 AM
mw1311 mw1311 is offline
Vehicle: 2012 Ram 1500 Lone Star
Trim Level: Lone Star
Rep:32
mw1311 is on a distinguished road
Originally Posted by mgrasber View Post
Unfortunately my truck didn't come with its manual. I did a quick search on the internet and was only able to find sites selling the manuals and not the actual manual itself so I figured I'd just ask on here. I'm sure it won't be the first "dumb" question I ask so please bear with me.
