Wrong octane... oops - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 12-29-2009, 01:00 PM
mgrasber mgrasber is offline
Vehicle: 2000 Ram 1500
Trim Level: Laramie SLT
Rep:34
mgrasber is on a distinguished road
Default Wrong octane... oops
Hey guys/gals,
was having a couple issues with the transmission in my new (to me) truck where it seemed like sometimes it couldn't find the right gear. Most of the time it's ok but every now and again it seems to struggle but usually for no more than a second (downshift and then almost immediately upshift into the correct gear).
The dealer/service guy mentioned that the truck had a custom dual exhaust when I asked him about modifications. Come to find out, it has an airaid CAI as well. I was rooting around in the engine bay and I came across a Jet performance module to boot (obviously not mentioned to me before purchase). I can only assume that the module is the stage 2 (because of the other mods on the truck) which I found out requires 91+ octane gas. I have been throwing the normal 87 in the tank because I didn't know the Jet was there.
Could this be causing the "transmission" issue that I mentioned above? If not, what issues could putting in the wrong octane gas cause? Thanks in advance for the help!
Old 12-29-2009, 01:10 PM
No I wouldn't think so . You may want to have your trans scanned for trouble codes . Could be a (input , output) sensor going bad . When was the last time the trans was serviced . You may not have records of that . Might not be a bad idea to get it done .
Old 12-29-2009, 01:15 PM
Resident Technician
Rep:1915
Have the trans software level checked as well. There may be an update for it that concerns shifting.
Old 12-29-2009, 02:57 PM
Rep:34
Doesn't look like the service center did anything with the transmission before I took it off their hands according to their records so they are going to do a flush and filter replacement on saturday. Hopefully that'll take care of the issue. I think they are going to run it for codes and I'll make sure to mention the software level check as well. Thanks again guys!
