Old 04-25-2010, 12:19 PM
kmart6215's Avatar
kmart6215 kmart6215 is offline
kmart6215 is on a distinguished road
Default no speedometer after a new fuse
Hi to all! Yesterday I was hooking up my car hauler to my truck and I didnot have a right turn signal and replaced the fuse. But I had a Head in A** moment and left my screwdriver on the edge of the engine compartment and it slid off and on the one of the spare relay spots and after I heard a pop, I now Have no speedometer and my ABS and Brake Light stays on. did I scewup something royally or do I need to just reset something or is there a fuseable link or fuse that I am missing. and will it harm anything to continue to drive it. the truck is a 2004 ram2500 heavy duty with the 5.9 cummins. thank-you ahead of time for everyones help!
Old 04-25-2010, 12:35 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
I would say go through and check all your fuses, inside and the engine compartment
Old 04-25-2010, 12:43 PM
Rep:1625
Sorry man, I don't have an answer for you, but I wanted to welcome you to the forum. We're glad to have you here!
Old 04-25-2010, 12:49 PM
kmart6215's Avatar
hey thanks for the welcome! It is great to find a place that has other dodge enthusiasts. And I know this may sound dumb but any Idea where to look for fuses that are inside of the cab. I have looked but have only found the main fuse box in the engine compartment.
Old 04-25-2010, 02:23 PM
Rep:1930
Not sure on yours but when you open the driver door up, on the side of the dash??? Probably blends in to the dash.
Old 04-26-2010, 07:18 AM
Rep:1909
Start by getting the ABS scanned for the stored codes and go from there.
Old 05-01-2010, 12:43 PM
kmart6215's Avatar
thanks to all of you that helped! I had the ABS scanned and it showed a code for an improper fuse amperage and so i changed that and went through all of the fuses and located a small fuse panel under the dash that held 4 fuses for the dash panel. What a pain to get to!! but after all of that It worked! A big thank you to each of you that helped out!
Old 05-03-2010, 09:21 AM
Rep:1909
Glad you got it taken care of without too much trouble.
