Old 12-30-2009, 02:59 PM
Rep:1845
Post DRL's
I also posted this in another thread but I'm also putting it here because I think it will get more reads.
In the intrest of settling this matter, I just went and got a '10 Ram Laramie Crew off the lot and hooked the scan tool to it. I searched the vehicle prep and customer preferences and there is no option for enabling DRL's. The only thing that can be done with the lamps is setting the delay time after the ignition is shut off, setting the illuminated entery time, and programming the auto lamps to come on with the windshield wipers. So as for now, unless you have a fleet or Canadian model, DRL's are not an option.
Old 12-30-2009, 03:27 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
I was expecting this to be the case. I think that a lot of car makers are cuting back on things and this was one of them. Thanks for checking though Remerson!
Old 12-30-2009, 04:25 PM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3944
That was nice of you Remerson! Thanks for helping the others out with this!
Old 12-30-2009, 04:29 PM
Rep:1845
It's also a good excuse to play with a $50k truck!
Old 12-30-2009, 04:33 PM
Vehicle: Blue
Rep:3944
I hope it was a blue one!
Old 12-30-2009, 04:38 PM
Rep:1845
Sorry, this one was white and mineral gray.
Old 12-30-2009, 06:36 PM
Indeepcamo's Avatar
Indeepcamo Indeepcamo is offline
Vehicle: 2010 2500 Mega Cab
Rep:30
Indeepcamo is on a distinguished road
Anybody know if this is the same case on the new 2010 Ram Heavy Duty.
Old 12-30-2009, 06:57 PM
Rep:1845
I'm pretty sure it is.
Old 12-30-2009, 11:42 PM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
DAYTIME RUNNING LAMPS
Vehicles manufactured for sale in Canada illuminate the high beam filament of both headlamps at a reduced intensity when the engine is running, the parking brake is released and the exterior lamps are turned OFF. The TIPM must be programmed appropriately for this feature to be enabled. Once enabled, anytime the TIPM receives electronic messages over the CAN data bus from the PCM indicating the engine is running and from the EMIC indicating the status of the headlamp switch exterior lighting input is OFF and that the parking brake is released, the TIPM provides a pulse width modulated voltage output to the proper headlamp bulb filaments through the right and left high beam feed circuits to produce illumination at a reduced intensity.
Could it be just a different flash for Canada?
Old 12-31-2009, 12:39 AM
Rep:1845
If the TIPM p/n's are the same, it would be in the flash.
