Sport Tow Hook Install With Pics - Page 9 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 07-03-2012, 12:39 AM
mrtosh mrtosh is offline
Vehicle: 2016 Ram Rebel
Trim Level: Rebel
Rep:12
mrtosh is on a distinguished road
Excellent! Thank you! Idk what the dealership was trying to sell me with the other part number.
Old 01-12-2013, 10:48 AM
rjmlakota's Avatar
rjmlakota rjmlakota is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:18
rjmlakota is on a distinguished road
Originally Posted by boomerman View Post
I looked up 2147471 and could not find anything on that number.
The 82210967 is a valid part number and it is for your 2012
http://moparonlineparts.com/product_...oducts_id/2511
I wonder if this will work on a 2013 Sport?
RJ
Old 11-11-2013, 12:07 AM
Bluedragon436's Avatar
Bluedragon436 Bluedragon436 is offline
Vehicle: 2009 Ram 1500
Bluedragon436 is on a distinguished road
Just picked up my 09 1500 a few days ago, and would def like to do this mod to it, as I always like having the front tow points just in case... I guess I'm just going to trim my stock bumper filler, if it doesn't come out like I want it too, then I'll look into picking up the stock filler that is already cut out... Thanks for the information guys..
Old 11-11-2013, 12:33 AM
SteelTownStang's Avatar
SteelTownStang SteelTownStang is offline
Rep:262
SteelTownStang is a jewel in the roughSteelTownStang is a jewel in the roughSteelTownStang is a jewel in the rough
RJ
I'd like to know as we'll... '14...
MODS: Magnaflow Cat-Back Exhaust, Extang Solid-Fold Tonneau, Mopar Side Steps, Mopar Mats & Bedliner, AMP Bed XTender, Daystar 2.5 Leveling Kit, Fuel Pump Black Wheels (20x9/+1 Offset), Toyo Open Country Extreme A/T Tires (35/12.50/20), Lund Fender Flares, Aries Stealth Bull Bar, & KC SlimLites.
Old 12-31-2013, 12:11 PM
Baja4701 Baja4701 is offline
Vehicle: 2014 Ram Sport
Baja4701 is on a distinguished road
I looked at a 2014 Laramie this morning and crawled under the bumper to see what the hooks looked like. Looks to me like the same ones would fit a 2014 Sport. Same exact chassis set up, same exact hole locations. I have a 14' Sport myself and I will buy the same ones that go on the Laramie.
I believe anyone telling us that you can't do it on a Sport is saying it because you have to do the cutouts and no longer is it "Stock".
Also, if anyone is unhappy with the cuts they make, get a couple of feet of Rubber U-Channel Extrusion. Start it on the bottom middle of the hooks and work it around. Then cut it for tight fit and end it at the bottom middle again. Drop a bead of Super Glue in the channel every few inches for security. This works great for the wide oval cuts. Looks Factory Installed. Form it perfectly by running your finger around the entire hole to form it into exact shape.
This is the link...It's the 2nd one from the left...Tight U...
http://www.westernrubber.com/product...bber-products/
Old 12-31-2013, 12:25 PM
Trim Level: Rebel
Rep:12
So will the tow hooks from a 2012 work for a 2014?
Old 12-31-2013, 12:55 PM
CCeastside's Avatar
CCeastside CCeastside is offline
Vehicle: 2010 RAM SLT 4X4
Trim Level: SPORT CREW CAB
CCeastside is on a distinguished road
have 2010 sport and put the hooks on mine and left off the plastic cover... if you have a Black truck this doesn't even match the color it's a greyish color.. so just left mine off and it looks 10X's better and you get so extra cooling letting in air running down the road.
Old 01-01-2014, 12:29 PM
I'll let you guys know. I just ordered the Hooks and the Hook Panel with Factory cutouts.
http://allmoparparts.com/1500-hook-p-2511.html
I did exact measuring on a 2014 Laramie versus my 2014 Sport...I'm VERY confident these will fit perfectly...
You use the 2 existing bolts on your truck and the hooks come with one bolt for each...This bolt goes on the Vertical portion of the frame and if you get under the front bumper, you will see there is a threaded piece on the underside of this vertical piece...It's oooozing the words "Put a Tow Hook Bolt on Me"...lol
Old 01-01-2014, 02:28 PM
Rep:262
Nice! Looking forward to hearing how it works out...
Old 01-08-2014, 06:32 AM
Lil' update. Just got the parts last night.
Tow Hook Panel.
The site says 2009-2014 but the description says 2009-2012.
I'm returning the panel. WILL NOT fit a 2014 Sport. It's not wide enough. BUMMER. I'll be cutting my original. No biggie.
For those looking to get this panel, here are the exact measurements of it, which SHOULD be on the site under description but aren't.
It is 43 1/2 inches wide
The middle is 2 inches high
The hook areas on the left and right side are 3 1/8 inches high
Been freezing my arse off all week, so the hooks won't go on until Saturday/Sunday. Will update then.
