tonneaucovered.com
Old 12-30-2009, 11:33 PM
Romato
Default Power steering
What type of fluid do I use to fill power steering on a 1999 dodge ram v8.
Old 12-31-2009, 12:40 AM
Resident Technician
Rep:1911
ATF+4 is what you need.
Old 12-31-2009, 12:58 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Yup. I don't think they even make ATF+3 anymore, eh? Damn, ATF+4 is bloody expensive!
Old 12-31-2009, 05:30 PM
Romato
Thanks guess I have to dish out some cash and get the right stuff
Old 12-31-2009, 05:37 PM
Resident Technician
Rep:1911
I haven't seen ATF+3 in a while. If you can find it, you can use it because that's what came in it. ATF+4 is backward compatible with +3.
Old 01-01-2010, 02:14 PM
Iggy Iggy is offline
Gender: Not Specified
Iggy is on a distinguished road
http://dodgeram.info/tsb/2003/19-005-03.htm
Date: Aug. 29, 2003
Models: 1994 - 2002 (BR/BE) Ram Pickup, 2002 - 2004 (DR) Ram Pickup
Discussion:
The factory fill power steering fluid for most 2004 model year Chrysler Group vehicles is ATF+4 (MS9602) and it provides superior performance at both low and high temperatures. WJ/WG and ZH vehicles use unique power steering fluids. Refer to the table to identify factory fill and the approved service power steering fluid by year and model. Note that MS9602 is Red in color and MS5931 and MS9933 are Amber/Yellow in color. All three fluids will darken in color with usage and fluid color is no longer an indication of fluid condition.
The part numbers for MS9602 are 05013457AA (quart) and 05013458AA (gallon). The part number for MS5931 is 04883077 (quart). The part number for MB345 is 05127381AA.
MS9602 should not be mixed or used as a “topping off” fluid on systems requiring MS5931. On some past models, MS9602 should be used as the replacement fluid. On these models, if a power steering system is being serviced that results in a large fluid loss, such as a pump, hose or gear/rack replacement, the complete system should be drained and filled with MS9602.
NOTE: This bulletin supersedes owner’s and service manuals for the vehicles listed above that may state to use MS9933 in the power steering system, and that may state not to use automatic transmission fluid in the power steering system.
The gist of it, if you have ms5931 (mopar power steering fluid) in you system already, then you SHOULDN'T top of with ATF +4 (ms9602)
Old 01-03-2010, 08:57 AM
Incognito's Avatar
Rep:72
Yeah, I'm pretty sure ATF+3 isn't made anymore. Valvoline makes the ATF+4 for Chrysler now.
