Old 12-31-2009, 02:49 PM
deryk111 deryk111 is offline
Vehicle: 2012 ram 1500
Trim Level: st quad cab
Rep:25
deryk111 is on a distinguished road
Default 33x12.50 on stock wheels
can i fit 33x12.50 procomp xtreme all terrains on my stock 06 1500 4x4? if not what do i gotta do to make them fit?
Rep:1877
Height wise, yes. I'd want a 10" wheel though.
Old 12-31-2009, 02:53 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
What size are your stock rims....mainly width? I agree with Remerson with the height . Im not familiar with stock size rims on your truck(year)
Old 12-31-2009, 02:56 PM
Normal rim width range for 33x12.50 is 8 1/2" - 11" . Recommended is 10" as Randy has stated .
Old 12-31-2009, 03:00 PM
I believe your stock wheels should be 8.5" wide. I think that's too narrow for the tire size you posted.
Old 12-31-2009, 03:16 PM
Rep:25
well i think there 9 inch wide actually but not sure ill have to look more into it. but im just not sure if anyone has done this and if they rub or not?
Old 12-31-2009, 03:39 PM
57Hemi08's Avatar
57Hemi08 57Hemi08 is offline
Vehicle: 2008 Dodge Ram
Trim Level: SLT Big Horn
Rep:42
57Hemi08 is on a distinguished road
Yes 12.5" will fit on stock wheels no problem. Now you might need a 1/4" spacer to keep from rubbing the sway bar but not 100% sure on 33". I know on 35x12.5R20 you need a 1/4" spacer on the front cause at full turn they slightly rub the sway bar. But with a 33" and no big side lugs like my nitto mud grapplers you probably won't need the spacer. So I'd say put the tires on and run them. If you notice any slight rubbing on the sway bar later on then you can pick up some 1/4" spacers from summitracing for about $7 each and you'll only need them for the front.
Old 12-31-2009, 11:48 PM
yotehtr yotehtr is offline
Vehicle: 08 Ram 1500
Trim Level: ST Reg Cab 4x4
Color: Metallic Gray
Rep:28
yotehtr is on a distinguished road
yes 12.50s will work on an 8" rim
Old 01-24-2010, 05:08 PM
08Shorty's Avatar
08Shorty 08Shorty is offline
08Shorty is on a distinguished road
Yep im running 35x12.5 on my stock 17x8's. Levelled the front with Bilstein 5100's & put 1'' wheel spacers on.
Old 01-28-2010, 03:25 AM
RamGentry13 RamGentry13 is offline
Vehicle: 2007 Dodge Ram 1500
RamGentry13 is on a distinguished road
good onfo 57ram08, you truck looks sick with those tires (and leveling kit?)!
