Old 01-01-2010, 03:00 PM
kicknjeep kicknjeep is offline
Vehicle: 1995 Dodge Ram 1500
Rep:26
kicknjeep is on a distinguished road
Default Adjusting tranny bands!
Anybody have a good write up in how to adjust the reverse band in my tranny(auto)?. 95 Laramie/5.2L, 4X4
Old 01-01-2010, 03:04 PM
Rep:1845
Do you know which trans you have?
Old 01-01-2010, 03:07 PM
Rep:1845
This is for the front band of the 42RE:
FRONT BAND ADJUSTMENT
The front (kickdown) band adjusting screw is located on the left side of the transmission case above the manual valve and throttle valve levers.
  1. Raise vehicle.
  2. Loosen band adjusting screw locknut Then back locknut off 3-5 turns. Be sure adjusting screw turns freely in case. Apply lubricant to screw threads if necessary.
  3. Tighten band adjusting screw to 8 Nm (72 in. lbs.) torque with Inch Pound Torque Wrench C-3380-A, a 3-in. extension and 5/16 socket. CAUTION: If Adapter C-3705 is needed to reach the adjusting screw , tighten the screw to only 5 Nm (47-50 in. lbs.) torque.
  4. Back off front band adjusting screw 2-7/8 turns.
  5. Hold adjuster screw in position and tighten locknut to 41 Nm (30 ft. lbs.) torque.
  6. Lower vehicle
Old 01-01-2010, 03:10 PM
Rep:1845
This is for the rear band of the 42RE:
REAR BAND ADJUSTMENT
The transmission oil pan must be removed for access to the rear band adjusting screw.
  1. Raise vehicle.
  2. Remove transmission oil pan and drain fluid.
  3. Loosen band adjusting screw locknut 5-6 turns. Be sure adjusting screw turns freely in lever.
  4. Tighten adjusting screw to 8 Nm (72 in. lbs.) torque
  5. Back off adjusting screw 2 turns.
  6. Hold adjusting screw in place and tighten locknut to 34 Nm (25 ft. lbs.) torque.
  7. Position new gasket on oil pan and install pan on transmission. Tighten pan bolts to 17 Nm (13 ft. lbs.) torque.
  8. Lower vehicle and refill transmission with Mopar ATF Plus, Type 7176 fluid
Old 01-01-2010, 03:12 PM
Rep:26
Sorry don't know which tranny I have, any way to check visually on tranny?. Also noticed the shifter linkage is misaligned. Won't even go down to 1st.
Old 01-01-2010, 03:15 PM
Rep:1845
Most likely you have the 42RE. The 46/47RE transmissions are a heavier duty design. If you PM me the last 8 of your VIN and approximate mileage, I can pull up your build codes and make sure.
