Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 01-01-2010, 02:04 PM
Rep:1885
Post DS Body Headlamp Removal
LAMP
<A xmlns="http://www.w3.org/1999/xhtml"> 1.Disconnect and isolate the battery negative cable.2.Remove the four plastic push-in fasteners (1) that secure the upper radiator seal to the grille support and both fender ledges.3.Remove the two plastic push-pin rivets (2) that secure the upper radiator seal to the radiator.4.Remove the upper radiator seal from the vehicle.
NOTE: It is not necessary to remove the grille from the front of the vehicle to service the front lamp units. The illustration shows the grille removed only to assist in clearly identifying the locations of the front lamp unit mounting provisions. 5.Remove the screw (1) that secures the upper mounting tab of the front lamp unit (2) to the Front End Module (FEM) carrier (also known as the radiator closure) (4).6.Using a socket with a magnetic insert or with a small piece of butyl tape inserted, reach down between the grille and the FEM carrier to access, remove and retrieve the screw (3) that secures the lower mounting tab of the front lamp unit.
<A xmlns="http://www.w3.org/1999/xhtml"> 7.Remove the fastener that secures the tab at the bottom of the access panel (2) to the front of the front wheel house splash shield (1).
NOTE: The illustration shows the back of right front lamp unit and slide lock with the slide lock in the locked position. 8.Reach through the access opening (1) of the wheel house splash shield and lift the slide lock (3) upward far enough to disengage it from the lock post (2) integral to the back of the front lamp unit housing (4).
<A xmlns="http://www.w3.org/1999/xhtml"> 9.From the front of the vehicle, grasp the outboard edge of the front lamp unit firmly and pull it straight forward to disengage the ball stud (1) from the plastic grommet in the FEM carrier.10.Pull the lamp away from the front of the vehicle far enough to access and disconnect the two wire harness connections from the park/turn signal bulb socket (4) and either the headlamp bulb (2) on vehicles with dual headlamps, or from the headlamp pigtail wire harness on vehicles with quad headlamps (not shown).11.Remove the front lamp unit from the vehicle.
Old 11-24-2010, 05:11 PM
Butter's Avatar
Butter Butter is offline
Vehicle: Ford owner as of 4-25-15
Trim Level: XLT
Color: Flame Blue Metallic
Rep:398
Butter is just really niceButter is just really niceButter is just really niceButter is just really nice
RamTech thank you very much for posting this, I just replaced my headlight bulbs and without this illustration I would have been lost! The first one took a while but the second one was swapped in a matter of minutes.....Removing the grill may not be necessary but it makes things a lot easier!
2010 Ram 1500 reg cab swb 4x4, 5.7 Hemi, 3:92 gears, Flowmaster 40 true duals, 2.5 leveling kit, Bridgestone Dueler 275/55/20 on KMC Skitch Wheels, DeeZee steps, BakFlip G2 tonneau cover, Weathertech Digital fit floor mats
Old 11-26-2010, 11:47 AM
KennyPowers's Avatar
KennyPowers KennyPowers is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:299
KennyPowers is a jewel in the roughKennyPowers is a jewel in the roughKennyPowers is a jewel in the rough
Sorry to thread jack, but can someone help me find a slide lock for the head light assembly? I snapped the one on the driver side when I removed my head lights a few weeks ago.
Old 11-26-2010, 12:04 PM
Rep:1885
Gonna be a dealer item. The part number is 68050777AA.
Old 11-26-2010, 03:03 PM
Rep:299
Thanks.
Old 11-12-2011, 08:12 PM
js1977's Avatar
js1977 js1977 is offline
Vehicle: 2011 Dodge Ram
Rep:124
js1977 will become famous soon enoughjs1977 will become famous soon enough
I wanted to add a few pictures to this to help out.
These are the tools you will need to make the job easier.
Ratchet
extension (really long one or a couple of short ones)
plastic rivet remover
flashlight
magnet (metal tool retriever)
11mm socket
Then of course you'll remove the items in the order that it states above. It states that you don't need to remove the grill to be able to remove the headlights but TRUST me, you DO need to remove the top bolts holding the grill on. Once you remove these you can move the grill forward enough to get to the lower bolt holding the headlight on.
These are the four bolts to remove to loosen up the grill to make work easier.
These are the two bolts you will have to remove from the headlight.
This is a picture of the plastic tab that you'll have to push up/down to remove headlight and reinstall it as well.
This is the connector that is holding the headlight, just pull straight out and then start to pull while rotating the headlight towards the grill. It comes out easier that way.
Once headlight is out, disconnect these two items.
Then sit the headlight down on something sturdy and remove the two covers as shown below. disconnect the wires from the bulbs and rotate the bulbs to remove them. Now your ready to install the new bulbs and go in a reverse order to put everything back together. I hope this helps some...
What do I know, I'm just some dumb peckerwood that lives in the country with too many guns...
Old 01-10-2012, 11:38 AM
Woolly11Ram's Avatar
Woolly11Ram Woolly11Ram is offline
Vehicle: 2011 Dodge Ram SLT
Woolly11Ram is on a distinguished road
Thank you for the headlight HOW-TO it was very helpful installing my new lights today.
Old 03-13-2012, 10:50 PM
TexasHarleyBoy TexasHarleyBoy is offline
Vehicle: 2009 Ram 1500
Trim Level: TRX
TexasHarleyBoy is on a distinguished road
Wow!!! Excellent feedback on this. Not to impressed with the way Dodge designed this, but VERY impressed with the knowledge of the Forumz members! Don't have any pics of my truck, but I'll try to get some soon. Thank y'all for the knowledge and the welcome wagon!
Old 02-18-2013, 01:56 AM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
Thanks for the info and diagrams.
Old 02-18-2013, 02:18 AM
Rep:2657
I just bought a replacement headlight for my '09
pix in no particular order
http://img856.imageshack.us/slidesho...1713670yy.smil
