Auxiliary Switch bank - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Interior and Exterior Lighting
Old 10-31-2010, 07:03 PM
lwalston's Avatar
lwalston lwalston is offline
Vehicle: 2010 Dodge Ram 3500 6.7
Rep:93
lwalston will become famous soon enough
Default Auxiliary Switch bank
Hello Everyone,
I'm wanting to install a switch bank to run my aux lights and 12 volt air compressor, train horns
The 5500 C&C comes with one that will fit in my dash, I have attached info on the one that comes in the 5500
Has anyone did this yet?
I have a plug with 3 wires connected to the blank plastic insert from the factory where the switch bank would go. Does anyone know what these wires are for?
The 5500 also has Power distribution box under the hood , Does anyone have the part numbers for the Switch bank, wire harness,Power distribution Box?
Les
[IMG]file:///Users/lwalston/Library/Caches/TemporaryItems/moz-screenshot.png[/IMG]
Old 11-01-2010, 06:43 PM
lwalston's Avatar
Rep:93
Default Maybe I posted this in the wrong place
Old 11-02-2010, 03:35 PM
jaynuke jaynuke is offline
Vehicle: 2013 Ram 2500 5.7L
Trim Level: Lone Star
Rep:14
jaynuke is on a distinguished road
Dud, don't give up, one of the brains will chime in.
Wish my '10 1500 had that option.
Jaynuke
Old 11-02-2010, 07:27 PM
lwalston's Avatar
Rep:93
Thank you Jaynuke
Les
Old 11-07-2010, 10:21 PM
Rep:3347
I can't say that I know the part number for the switch bank, but I'm making my own bank from a piece of plexiglass and mounting it in the lower opening on my dash. I have plans to fiberglass it in smooth and use the momentary/latching illuminated push switches from Oracle. It'll hold 5 switches, train horn, N2O arming, N2O purge, rear helper 'bags, and interior lighting.
Old 12-07-2010, 07:06 PM
emtnfirefighter emtnfirefighter is offline
Vehicle: 2009 Dodge Ram 1500 4x4 SLT
emtnfirefighter is on a distinguished road
http://www.************************/d...s-t269911.html
Part number listed in on this other forum
part # 5164912AC
If you cant DODGE it, RAM it!
Old 12-07-2010, 07:38 PM
lwalston's Avatar
Rep:93
Thank you, I will call my dealer with that number tomorrow.
Les
Old 12-07-2010, 07:51 PM
NP, I am trying to find pics of the back, to see if it will work for my application
Old 12-11-2010, 09:06 PM
lwalston's Avatar
Rep:93
Default Pictures of installed switch bank
Installed my Aux switch bank today. Here are some pictures.
Old 12-11-2010, 09:09 PM
lwalston's Avatar
Rep:93
I'm going to run my driving lights, Roof mounted lights, Train Horn, Not sure about the 4th switch yet. I have $140.00 in the switch bank and pigtail/wires.
two of the switches are rated at 40AMP and 2 at 25AMP. I'm still going to run them through relays. One thing I dont like about the switches is when the switch is off there is 12 volts on the output wires, when you turn switch on voltage goes to 0 volts. I had no wiring diagram and hope someone on here knows if this is the correct operation of the switches.
Les
