Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 01-01-2010, 08:01 PM
Ram-RN's Avatar
Ram-RN Ram-RN is offline
Vehicle: 2002 Dodge Ram Quad 5.9
Ram-RN is on a distinguished road
Default U joints
How much would it cost to repair u joints if I take it to a shop. I'm just trying not to get ripped off.
Old 01-01-2010, 08:04 PM
Rep:1885
How many joints and which ones, drive shaft or axle joints?
Old 01-01-2010, 08:20 PM
Ram-RN's Avatar
Took my truck to firestone today because of a noise(clicking) while the truck was starting to take off. I also had some leaking my power streering. The replaced the rack and pinion changed some hoses etc. After the discount they charged me $810. They said the clicking was gone. I went to the parking lot to drive off and the same clicking was still there. Man WTF?! So I go back there and one of the tech checked out the back and said your rear u joints have play and has to be replaced.
What is a consumer to do. I decided to skip my dodge dealership because they did not repair the problem just left me with a 1200 bill but the problem still persisted. I am no mechanic but the tech said it was the rear ones.
Old 01-01-2010, 08:21 PM
Ram-RN's Avatar
I believe he said the drive shaft and only one of them
Old 01-01-2010, 08:23 PM
Rep:1885
Might as well get them both done' Parts will vary depending on the quality and location, but the labor should be around 1.5 hours times their rate.
Old 01-01-2010, 08:24 PM
Rep:1885
Sounds like you had some hacks working on your truck. A loose u-joint isn't hard to find.
Old 01-01-2010, 08:27 PM
Ram-RN's Avatar
Thanks remerson....i guess i'm going to have to eat the cost of the rack and pinion. Who knows if it really had to be replaced
Old 01-01-2010, 08:33 PM
Rep:1885
Probably didnt unless you had some sloppy steering or a major leak. I'd raise hell over that. If that doesn't work there's always the Better Business Bureau.
Old 01-01-2010, 08:46 PM
Ram-RN's Avatar
Unfortunately if this is the case. They are quick to take your money. That's the problem nowadays. I tried calling the manager to get the rack and pinion assembly. He was making up some excuse that they needed to send it off to the supplier for core re-imbursement. I think they are just trying to cover their a$$es. I will definitely take this to the BBB.
Old 01-01-2010, 08:54 PM
Rep:1885
He's right about that part. There is a core charge on the rack and what they installed is most likely a reman unit. If it hasn't been but a day or two, the parts store may still have it.
