Old 01-02-2010, 11:52 AM
ramz267's Avatar
ramz267 ramz267 is offline
ramz267 is on a distinguished road
Default How do you remove the bezel?
im putting a double din screen in my truck today and i need to know some tips on how to remove the bezel on my 08 dodge.
Copper orange RAM 1500 4x4 (larrime) 5.7l hemi!
'Orange Thunder'
Old 01-02-2010, 11:56 AM
BlueJet BlueJet is offline
Vehicle: Blue
Rep:3934
I know you have an '08 but I found this....
http://www.ramforumz.com/showthread.php?t=42516
Old 01-02-2010, 11:57 AM
Resident Technician
Rep:1909
REMOVAL
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, seat belt tensioner, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and personal or fatal injury .
<A xmlns="http://www.w3.org/1999/xhtml"> 1.Disconnect and isolate the negative battery cable.2.If equipped, remove the floor console.3.Remove the cup holder if equipped.4.On vehicles with a close out panel, remove the screws (3) and remove the close out panel (2).
<A xmlns="http://www.w3.org/1999/xhtml"> 5.Remove the screws (2).6.Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the instrument panel center bezel (1) to the instrument panel.
<A xmlns="http://www.w3.org/1999/xhtml"> 7.Disconnect the wire harness connectors (4) and remove the center bezel from the vehicle.
