Old 01-02-2010, 01:04 PM
harley30041 harley30041 is offline
Vehicle: 2004 Dodge Ram
harley30041 is on a distinguished road
Default Changing front left turn signal
How do you change the front left turn signal on a 2004 Ram? There doesn't seem to be a clear access to the headlight assembly. I know it's probably a simple solution but after an hour I couldn't figure out how to access it.
Old 01-02-2010, 01:07 PM
Rep:1909
REMOVAL
  1. Disconnect and isolate the battery negative cable.
  2. Remove the push pins attaching the seal to the fender.
  3. Remove the bolts attaching the headlamp unit to the fender.
  4. Remove the bulb sockets from the headlamp unit
  5. Separate headlamp unit from vehicle.
Old 01-02-2010, 04:15 PM
Many thanks. Appreciate it.
