System Install Help!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-02-2010, 08:08 PM
txlnghrn10's Avatar
txlnghrn10 txlnghrn10 is offline
Vehicle: 2013 RAM 1500 Express CC
txlnghrn10 is on a distinguished road
Send a message via Yahoo to txlnghrn10
Default System Install Help!!!
I installed my amp and new speakers today. I used the PAC C2A-CHY harness to hook the amp up to my factory radio. I'm getting a crazy amount of static back through my speakers.
I ran the power and the RCA's about a foot away from each other. I gounded the amp to the sheetmetal under my seat. There is a little black wire off the PAC harness, so I grounded that to part of the dash frame.
What gives?
Old 01-02-2010, 08:14 PM
Resident Technician
Rep:1915
Connect the 18-pin Molex and 11-pin output connector to the C2A-CHY interface. There is a Black wire coming out of the C2ACHY.
This wire will not be used in all installations. Test your amplifier for continuity from the RCA shield to the ground connection
terminal. If continuity exists, do not connect this black wire, isolate and do not use. If there is no continuity or if there is
high resistance between these two points, connect the black wire to the radio’s ground wire.
Did you remove the paint under the ground wire for your amp?
Old 01-03-2010, 11:28 AM
txlnghrn10's Avatar
What do they mean by "continuity"?
Old 01-03-2010, 12:40 PM
rickerred's Avatar
rickerred rickerred is offline
Vehicle: 2011 Sport
Rep:43
rickerred is on a distinguished road
Define: Test your amplifier for continuity
Definition: An electrical test used to determine the presence and location of a broken connection.
You are going to need a multimeter.
Mods: Garmin GPS, Trifold Tonneau Cover, Molded Mud Flaps, K&N Cold Air, Westin Oval Step Sides, Vent Visors, Bully Dog GT Platinum.
Future Mods: What ever I can sneak by my wife.
Old 01-03-2010, 02:34 PM
blownengine's Avatar
blownengine blownengine is offline
Vehicle: 2003 Dodge Ram
Trim Level: SLT Sport Package
Rep:35
blownengine is on a distinguished road
I would test the amp's ground like remerson said. You might need to route to the power and RCA's on opposite sides of the vehicle too
Old 01-03-2010, 05:30 PM
txlnghrn10's Avatar
I reground the amp to some thicker metal on the floor pan. I recrimp the ground wire and verified all the connections are solid. The static is only present when the truck is started. It's loud with the ground form the pac harness grounded and louder when it isn't.
Old 09-18-2013, 06:04 PM
miamidad miamidad is offline
Vehicle: 2012 Ram Express Crew Cab
Trim Level: LSD, TBCG
Rep:54
miamidad will become famous soon enough
I know this is an old thread.....but i am wondering if you resolved this issue. Please let me know if you did and how you did.
I am having a similar problem.
Thanks.
