Old 01-02-2010, 09:51 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
Default Question about ETC light on in my cluster
I have a 2004 ram 5.7 and this started today and it did get cold out today but anyways, i was out and went in a parking lot to cut acrpss and gave it a little gas to fish tail a little, and then the light came on and i lost some power. then we parked and went into the store i came out and the light was out and everything normal. Then tonight we were taking a friend home and was going up a hill that was a bit slippery so i kicked it down a gear and it set the light off, so i dropped them off and pulled over and shut it off and restarted it and the light was out and everything back to normal. So i was playing around on the way home reving it and such seeing what set it off and i went around a corner and punched it to see if it came on and sure enough it came on and the truck kinda backfired and reved down. so i drive home and parked it and here i stand asking you guys if anyone would possibly know an answer to my question?
Also note the light was flashing not solid.
Please help me out, thanks!
Old 01-02-2010, 10:33 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
What is an ETC light? By chance do you mean ESP?
Old 01-02-2010, 10:39 PM
Vehicle: SRT-10
Rep:434
Ya in my manual it says its the etc light and its only on 5.7 hemis and its stands for Electronic Throttle Control.
Old 01-02-2010, 11:20 PM
Rep:1909
ETC is electronic throttle control. You need to have the PCM scanned for related codes.
Old 01-03-2010, 09:13 AM
Ram Rod's Avatar
Ram Rod Ram Rod is offline
Vehicle: 2005 Dodge Ram 1500
Color: Blue
Ram Rod is on a distinguished road
Not positive it is the same thing, but i used to have a 5.9 ram that did the same sort of thing. only I had to disconnect the battery to reset it. on that truck it was the throttle position sensor.
Old 01-03-2010, 09:18 AM
Rep:1909
It's not the same. The 5.9 uses a throttle cable instead of drive by wire.
Old 01-03-2010, 04:23 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Ah I see. Had no idea it was electronic on the new ones. Someday I'll get a new truck Lol.
Old 01-03-2010, 04:54 PM
Audi doesn't make a truck !
Old 01-08-2010, 05:54 PM
freyb08 freyb08 is offline
freyb08 is on a distinguished road
Default E.t.c( elctronic throttle control)
I have the same problem. my error codes are P2173 and P2106. started last week when I started it and let it idle to warm up on a cold night. It went into limp mode. It reset itself when I shut it off. Then did it again later that night.
I put dry gas in it and let it sit in the garage for 4 days. started it today and let it idle for 10-20 min. and the light came on again and it went into limp mode again.
03 dodge ram 1500 quad cab
5.7 L 2 wheel drive
56k miles
error codes
P2173
P2106
Old 01-08-2010, 06:46 PM
Rep:1909
P2174 or P2175 maybe? Can't find a p2173 listed.
P2106 - NOTE: This is only an informational DTC. This code should set along with
other DTCs. All other DTCs must be properly diagnosed before continuing.
The RPM or power are limited when P2106 sets for safety reasons because other ETC
related DTCs have set.
