Old 01-04-2010, 06:50 AM
RAM460v RAM460v is offline
Vehicle: 2003 Dodge Ram 1500
Color: Charcoal Gray
RAM460v is on a distinguished road
Default Heater question
Hi
First time posting here, from what I have seen this site is great, very informative and helpful.
I have a 2003 Dodge 1500 3.7 Ltr. I have only owned it since May 2009.
When I bought it it only had 30,000 miles on it, looking forward to along term relationship with the truck.
I have notice since winter when I start the truck and let it warm up, it will not start to blow heat until I rev it up. It blows a little warm but not hot. even if it idles for 10 - 15 minutes. I was wondering if this was normal? I was thinking maybe thermostat problem, not sure.
A friend of mine says "it might be because of the low idle RPM, its the way those trucks are" Does not sound right to me.
Any suggestions will be appreciated
Thank YoU
RAM460v
Old 01-04-2010, 08:18 AM
Rep:1909
Most likely a thermostat problem or air in the system due to low coolant. The water pump is also possible, but less likely.
Old 01-07-2010, 11:52 AM
Remerson thank you for your response, the fluild was low and I replaced the cap. I probably should have checked fluid level first. I need to keep an eye on the level in case there is another problem.
RAM460v
Old 01-07-2010, 11:54 AM
Rep:1909
Sounds like you've got a handle on it.
Old 01-11-2010, 06:50 AM
Well I think I found out why the fluid was low. The bottom sqeeze type hose clamp was split. I do not know why I never found a leak on the driveway. From the rust on the break it has been that way for a while. Laying out in the snowy driveway Sunday morning sucked, but I finally was able to cut off the old clamp with a Dremal and replaced the clamp. Time will tell... again
Thank you
RAM460v
Old 01-11-2010, 08:46 AM
Glad ya found the problem.
Welcome to the forum.
