Old 01-04-2010, 09:46 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Lol I'm sure there will be another issue to be discussed in which I am in desperate need of help. Lets hope thats not the case.
Old 01-05-2010, 01:18 AM
34blazer 34blazer is offline
Vehicle: 1997 Dodge Ram
Trim Level: SS/T
Color: black/silver stripes
34blazer is on a distinguished road
i thought the fuel pressure was 39#? either way, check the fuel pressure, that could very well be the problem.
Old 01-05-2010, 05:26 PM
Zekery360 Zekery360 is offline
Vehicle: 2002 Dodge Ram
Color: Bright Red
Zekery360 is on a distinguished road
Could the PCV be pulling really nasty stuff in from the crankcase and dirtying the IAC? Just thinking out of the box a bit, but if cleaning that fixed it last time, maybe it just is getting really dirty really quick from something like that? Anyways, let us know what it is. I am getting really curious what is causing so much issues.
Old 01-05-2010, 07:40 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Well my last oil change was to synthetic... Don't you have to change that pretty quickly the first time?
Old 01-05-2010, 07:44 PM
Rep:1877
That's the rumor but I've never seen any studies to back it up.
Old 01-05-2010, 07:48 PM
I would check the fuel pressure also . Hopefully you can catch it when it bogs down . I don't think you have water in the fuel . If the fuel pressure test comes back ok , I would have a tendency to look more towards like the map sensor . I have run into alot of map sensor problems and they won't necessarily set a code . One of the most overlooked sensors .
Old 01-05-2010, 09:05 PM
Color: Bright Red
Good call on the map sensor. The easiest test I heard it to tap the sensor with like a screwdriver handle or something while the engine is running and see if it sputters or dies. Scan tool would catch that one too.
Old 01-05-2010, 09:39 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Well at a full tank it is fine, but down to about half tank or so then the bogging starts and at 1/4 expect death. Would a fuel pump act up when the gas tank gets lower?
Zekery with your test, I end up pulling it out and tapping it or leave it on and tap it? Probably a dumb question, but I am trying to be super specific before I start tapping a sensor.
Old 01-05-2010, 09:45 PM
Color: Bright Red
Leave it on and connected right where it is. And be very careful with your taps. Don't want to break it if it isn't broken.
Old 01-05-2010, 11:30 PM
Not sure thats a good test . Back in the 80's that was a test on the old maf sensors on GM cars .
