Old 01-06-2010, 07:15 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I do not believe so actually. Can you explain?
Old 01-06-2010, 07:19 PM
Rep:1909
A crank position sensor tells the PCM where the crank is in its rotation. An intermittent signal can cause dying, popping, hard starting, misfires and the like and they won't always set a code when they go bad.
Old 01-06-2010, 07:22 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
I see, that does sound strangely like whats going on.
I've also noticed that it feels very weird at idle. It idles O.K. but it is almost like a misfire occurs. Like it'll go quiet, then get loud again. I wish I could just show it to you guys lol.
So it can fly under the radar when it goes bad? Would this be an install I could do at home? I wouldn't like to take it all apart, but whatever saves me cash Lol.
Old 01-06-2010, 07:29 PM
Rep:1909
CRANKSHAFT POSITION SENSOR - 3.9L/5.2L/5.9L ENGINES
REMOVAL
The sensor is bolted to the top of the cylinder block near the rear of right cylinder head.
  1. Remove the air cleaner intake tube.
  2. Disconnect crankshaft position sensor pigtail harness from main wiring harness.
  3. Remove two sensor (recessed hex head) mounting bolts
  4. Remove sensor from engine.
INSTALLATION
  1. Position crankshaft position sensor to engine.
  2. Install mounting bolts and tighten to 8 Nm (70 in. lbs.) torque.
  3. Connect main harness electrical connector to sensor.
  4. Install air cleaner tube.
Old 01-06-2010, 10:10 PM
Done all by feel . Can't see it if your working from the engine compartment . 2 bolts and disconnect the wiring harness . Be careful not to drop the new one . Fragile . Seen guys drop the new ones putting them in and still won't start . Replace with another one starts fine .
Old 01-08-2010, 12:35 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
I am taking it to a shop tomorrow. Died a good 20 times after school yesterday.
Old 01-08-2010, 12:41 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Whoa! That sucks. Hope it is something simple.
Old 01-11-2010, 06:03 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
Finally, took it into a respectable shop today. I wonder if we were right on the problem Lol. This shop is amazing, we had problems with our old saturn back in the day, they misdiagnosed the problem, after my parents had bought a battery, when it was the alternator. They paid us back for the battery and installed a brand new alternator at no charge. Awesome shop.
Old 01-11-2010, 07:54 PM
98sst's Avatar
Trim Level: SS/T
Rep:883
They reset the memory (unplug negative battery cable?)
They said if it doesn't act up tomorrow they are giving it back. Kinda makes me feel stupid cause its so sporadic
