Weird noise coming from pulley? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-05-2010, 11:09 PM
MrCantu's Avatar
MrCantu MrCantu is offline
Vehicle: 2002 Dodge Ram 1500
Rep:164
MrCantu has a spectacular aura aboutMrCantu has a spectacular aura about
Exclamation Weird noise coming from pulley?
Hey guys there's a weird noise coming from a pulley, and I'm not a gear head like most of the guys around here... I was thinking maybe getting it replaced either buying a used one or getting it new, here's a quick video of the noise it makes
Any questions let me know!
Old 01-05-2010, 11:19 PM
Kind of hard to hear .
Old 01-05-2010, 11:24 PM
Resident Technician
Rep:1915
Sounds like a belt or bearing noise. Try spraying some belt dressing or silicone spray on the belt when its running and see if the noise changes.
Old 01-05-2010, 11:33 PM
MrCantu's Avatar
Rep:164
I changed the belt about 2 weeks ago so I know it can't be the belt, and like you said it might be a bearing... I will check on autozone tomorrow.
Old 01-05-2010, 11:36 PM
Resident Technician
Rep:1915
Like Tom said, it's a bit difficult to make out, but an alternator or water pump bearing wouldn't surprise me too much.
Old 01-06-2010, 01:40 AM
Rep:2929
OK, i'm only a shade tree mechanic, this is what i would do, to make sure where the noise is coming from, take something like a cut off broom handle, about 3 feet long, hold it against the part that you believe its coming from, or close to it. hold the other end with your hand, put your ear on your hand, with a slight separation between the stick & your ear, use it on all pulleys, believe me, it works as good as a stethoscope. you can also use this method to figure out other noises around your engine compartment, tappet noise, etc
Old 01-06-2010, 10:02 AM
kicknjeep kicknjeep is offline
Vehicle: 1995 Dodge Ram 1500
Rep:26
kicknjeep is on a distinguished road
Ok I know Jeep TJ's (AKA MOPAR) and they are notorious for the idler pulley squealing and that looks to be what you are pointing/leaning at, So that would be where I would be starting.
Old 01-06-2010, 10:10 AM
Resident Technician
Rep:1915
Or the tensioner for that matter. Take the belt off and spin each pulley by hand and check for roughness, excessive looseness and noise.
Old 01-07-2010, 10:50 PM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Loosing any coolant? Wobbling water pump pulley would allow a little slack.
Old 01-08-2010, 10:12 PM
MrCantu's Avatar
Rep:164
I will take a look on that.
Will do that see if I can find what it is.
Hmmm I guess I need another video to show you that!
