Rubbing/Grinding Noise During 4WD - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 12-08-2009, 07:33 PM
Ramboi92's Avatar
Ramboi92 Ramboi92 is offline
Vehicle: 1995 Dodge Ram 1500
Trim Level: Laramie SLT
Color: Pearl Emerald Green
Rep:13
Ramboi92 is on a distinguished road
Default Rubbing/Grinding Noise During 4WD
Everytime I have my 4WD on (hi or low), when I speed up I hear this loud rumbling noise, like something is rubbing or grinding. It gets louder, the faster I go, and stops as soon as I let off the gas. Does anyone know what could be wrong?
Nitto Trail Grapplers wrapped around 18" Mamba M3's. They'll take me anywhere. In 2wd.
Old 12-08-2009, 08:45 PM
Rep:1915
Which transfer case do you have?
Old 01-07-2010, 05:45 PM
drtnshtr drtnshtr is offline
Vehicle: 2006 Dodge Ram
drtnshtr is on a distinguished road
somebody please answer this I have the exact same issue
Old 01-07-2010, 08:05 PM
Rep:1915
Slack in the chain would be my first guess.
Old 01-07-2010, 08:09 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Is the noise coming from the transfer case exactly or could it be the rear end? Took a Ram out before i bought the one i did and the same sort of noise was there. It ended up being bearings i believe in the rear end. ?
Old 01-08-2010, 12:15 AM
its definitley coming from the front on my truck and it only does it in 4 wheel drive.
Old 01-08-2010, 12:24 AM
Rep:1915
Have you checked the u-joints on the front drive shaft and the axle joints at the hubs? Check the yoke on the front diff for any vertical movement or excessive backlash.
Old 01-08-2010, 10:40 AM
I havent checked them yet but I hacve been told before thats what it probably is. Should I just put them up in the air and check for slop?
Old 01-08-2010, 11:13 AM
Rep:1915
The u joints may not be loose but could still be bad. I'd take the shaft out and check for looseness or excessive tightness that would indicate that the grease in the caps has dried out. you should be able to check the axles by moving them around by hand. When you get the front end in the air, grab the wheels and check for bearing looseness vertically and horizontally. Take off the front wheels and check the axle nuts for looseness.
Old 01-09-2010, 07:13 PM
maniac maniac is offline
Vehicle: 1999 ram 2500
Trim Level: laramie SLT
Color: RED
maniac is on a distinguished road
I had the same grinding-popping sound only in 4. went away when i let of accelerator. I changed the u joints and yoke in the front shaft. the yoke was dried out and the needle bearrings were ground into dust. not a single noise after new yoke and u joints. easy fix.
