Old 01-10-2010, 12:09 AM
Ramminit54's Avatar
Ramminit54 Ramminit54 is offline
Vehicle: 2009 Dodge Ram 1500 4x4
Trim Level: Laramie (Quad Cab)
Color: Black Crystal Pearl
Ramminit54 is on a distinguished road
Well, I finally changed it. What a pia. How do you guys thats changed an 09 keep from getting it all over the place taking off the filter. I made a big mess. I've changed the oil & filter many times on different vehicles, but never made a mess like that.
Leon
Old 01-10-2010, 01:34 AM
Get Bit's Avatar
Get Bit Get Bit is offline
Vehicle: 2004 Dodge Ram RC 4x4
Trim Level: SLT Sport
Rep:71
Get Bit will become famous soon enough
I run all Napa Gold filters in all my cars and have for many years.. They are made by Wix and are the best filters period.. IMO of course!
Old 01-10-2010, 02:12 PM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
Originally Posted by Ramminit54 View Post
Does anyone know for sure if a Mobile 1 M1-210 oil filter will fit an 09 Ram 1500 Laramie Quad Cab 4x4? I got it at Autozone, (they said it would) but I wanted to be sure before I got started.
Thanks,
Leon
Not sure about the M1,,,
From what I've read, you need a filter with: Thread Inside Diameter: M22 x 1.5 special (M6)
LOTS of controversy and mis-information on MFG's websites and application catalogs about which filter the 09's take,,,
(For instance, The PH2 listed as a 'fit' for an 09 on the Autozone site does not have the special pitch threads.)
Wix 57899 and Pure One PL24651 both indicate on their websites a "M22 X 1.5 'special' or 'M6' " thread,,, I believe K + N 2010 does as well.
One way to check to see if the filter you plan on getting will fit your 09,,,, If the same filter is listed as fitting pre-2009 models, it won't have the required 'special' thread pitch
Old 01-10-2010, 03:19 PM
Ramminit54's Avatar
Well, I hope it's the right one because I put it on last night. It went on easy (no binding). I haven't driven it or looked under it since though.
Old 01-10-2010, 03:33 PM
Ramminit54's Avatar
Originally Posted by Blackzilla View Post
ran that Mobil 1 filter first change.......now use napa gold.
Did you change because you thought napa gold was better, or did you have problems with the mobil 1? I ask because of this post
Old 01-10-2010, 10:37 PM
Color: Hot pink
Rep:135
I did some more checking, and the info is still 'all over the map' on this subject.
I did find a Charger forum that indicated the M1-201 fits the 'new' Hemi's,,,
Mobils website says -201 applications include 08-10 5.7 Rams,,,
Chances are, if it went on like it should have, I'd say it's 'good to go'.
Old 01-11-2010, 06:38 PM
Ramminit54's Avatar
Thanks HoustonHemi & others for your help.
Old 01-12-2010, 08:21 PM
Color: Hot pink
Rep:135
OK, I did a little more research,,,,
Gotta eat some crow,,,
The 'old' hemi filter was a PH-16, the 'new' hemi filter IS the PH-2,,,
My mind evidently tried to convince me that anything associated with the 'antique' PH-2 could NOT be new!!!! (Confusion exists, and it looks like I'm confused as well!!! )
The 'old' mopar hemi filter is the 090, the 'new' is the 899,,,
I had a chance to look at both the PH-2 / PH-16 and 090 / 899 in person today,,, the 'old' filters have a smaller threaded inlet than the 'new' versions.
Per the Wix website,,, An 07 Hemi takes part # 51085. Thread Size: 3/4-16
http://www.wixfilters.com/filterlook...&TempYear=2007
An 09 Hemi takes a # 57899 Thread Size: 22X1.5 MM 6-H
http://www.wixfilters.com/filterlook...&TempYear=2009
3/4" = .75" .75 " = 19.05 mm
http://www.metric-conversions.org/le...illimeters.htm
The 'old' filters with their ~19~ mm threads are a bit small for a motor designed to accept 22mm threads,,, I don't think you could get the 'old' filters to even come close to threading up 'correctly' on a 'new' motor,,,
But, some folks can be pretty persistent!!!
Old 01-12-2010, 08:44 PM
I haven't had the opportunity to change the oil on a '09 or 10 yet . I'm sure theres a trick or two that can be done . Once I do one I'll let you guys know . Maybe even post some pics .
Old 01-12-2010, 09:05 PM
HemiCrew's Avatar
HemiCrew HemiCrew is offline
Vehicle: 2014 Ram 1500 Hemi Crew Cab
Rep:51
HemiCrew will become famous soon enough
I ran into this issue when I changed my oil last week. I went to Walmart and I just figured (without consulting the filter catalog) that the M090 Mopar filter would fit my 09 hemi as it did my 07 Charger R/T. Wrong. There is no way anyone could get the M090 on a new Hemi truck. The inlet diameter is not even close. So I crawled out from under my truck dog cussing myself for not checking the catalogue and went back to Walmart. I even had to take jokes from my wife about buying the wrong filter. It was Sunday and the local dealers are closed so I did not have the option to purchase a Mopar filter that fit. I ended up reading the catalog and found that the Fram PH-2 & XG2 filters fit. Sure enough the XG2 did fit. I will switch to the correct Mopar filter at the next change. Moral of the story is always read the manual, don't assume.
