Old 01-10-2010, 09:48 PM
dirtsurferus dirtsurferus is offline
Vehicle: 1998 Dodge Ram 1500 5.9L
Trim Level: Laramie SLT
Color: Red/silver
dirtsurferus is on a distinguished road
i think that i should mention this too... idk if it is related but.. there is no visible oil leak anywhere on the truck. i just changed the oil to full synthetic...not even 5 months ago...(mid september) and when i go around a corner really hard or stomp the brake or even if it is sitting on a slight incline the check gauges light comes on and the oil gauge drops to none for about 1-2 sec then goes back to normal. it has done this before and i changed the oil and it stopped doing it. i checked the oil and the oil was right at the midway between full and empty line but the truck had been running for about an hour. i know for a fact that the oil level after i changed the oil was perfect while the engine was cool. could the oil leak possibly be the culprit for this too if there is in fact a bad gasket?
Old 01-10-2010, 10:12 PM
RamTech RamTech is online now
Rep:1885
If you're using that much oil, your intake pan gasket is probably blown. I've posted in a thread on how to diagnose it but I'll have to find it. http://www.ramforumz.com/showthread....409#post133409
Old 01-31-2010, 01:19 PM
1970swbc10's Avatar
1970swbc10 1970swbc10 is offline
Vehicle: 1999 Dodge Ram 1500 4X4
1970swbc10 is on a distinguished road
Randy,
Please post the repair procedure for replacing the pan gasket. My 99 has all the symptoms of a bad intake gasket.
Thanks
JEFF
5.9l, engine, transmission
