Old 01-10-2010, 01:38 PM
ramtruck99 ramtruck99 is offline
Vehicle: 1999 Dodge Ram 2500 Quad Cab
Trim Level: XLT Lariat
Color: Green
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
ramtruck99 is on a distinguished road
Exclamation Ignition run fuse
My ignition run fuse keeps popping when I try to start the truck. I have removed the ignition switch and checked it with an ohm meter but I don't know if it is ringing out where it is suppossed to or not. Any advice would be greatful!
Old 01-10-2010, 01:40 PM
Rep:1885
Is it just popping in the start position?
Old 01-10-2010, 01:42 PM
Welcome to the forum!
Take a few moments to visit your User CP and add the details on your truck. That will help us help you when you have questions.
Also, when you have the time, go to the Newbie Check In section and introduce yourself to the members here. Tell us about your truck, yourself and post up some pictures. We loves pictures!
Old 01-10-2010, 01:52 PM
Color: Green
yes it only pops when I turn it to the start position. I eplaced the starter about 1 year ago and have checked all the wires, no issues there that I can see. I am getting a ring out on the two end terminals of the switch and on the two left terminals.
Old 01-10-2010, 01:55 PM
Rep:1885
Gonna need info on your truck.
Old 01-10-2010, 01:58 PM
Color: Green
what info would you like?
Old 01-10-2010, 02:01 PM
Rep:1885
Year, model, and engine would be a good start.
Old 01-10-2010, 02:04 PM
Color: Green
1999 2500 5.9 cummins, 256000 miles, quad cab, even windows and heater motor stop working when fuse is blown.
Old 01-10-2010, 02:12 PM
Rep:1885
Are you blowing fuse 10 in the PDC? That's the 40 amp fuse in the box under the hood.
Old 01-10-2010, 02:15 PM
Color: Green
Nope, only fuse 2, the pink 30a fuse. Gone through about 6 of those now. Should the switch be ringing out at 2 spots on the ohm meter?
