Lowered, now have a steering prob... - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-14-2010, 10:08 PM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
Originally Posted by Toms Blue Ram 1500 View Post
Did you get the print out of your alignment ? If so what was the actual readings for left and right caster .
I got an alignment package from tires plus...they suck! at least the one where i live does. they do not give a printout of the readings. what type of readings should i be looking/ asking for, + or -?
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 01-14-2010, 10:38 PM
Resident Technician
Rep:1915
WHEEL ALIGNMENT
NOTE: All alignment specifications are in degrees.
NOTE: All wheel alignments are to be set with the vehicle at curb height.
Left Right
Camber - Preferred - .10 deg. Preferred -.10 deg.
Range -.40 to .60 deg. Range - .60 to .40 deg.
Cross Camber Preferred - .20deg. Range - -.30 to .70 deg.
Caster (20's) - 3.50 deg. 3.90 deg.
Range - 3.00 to 4.00 deg. Range - 3.40 to 4.40
Cross caster - -.40 deg. Range - -.90 to .10
Caster (17's) - 3.50 deg. 3.75 deg.
Range - 3.00 to 4.00 deg. Range - 3.25 to 4.25 deg.
Cross Caster - -.25 deg. Range - -.75 to .25 deg.
Toe - .10 Split equally between both sides. Range - .0 to .20 deg.
Old 01-14-2010, 11:26 PM
curt4816's Avatar
Rep:178
Thanks Ramerson!!!!
Old 01-15-2010, 08:37 PM
curt4816's Avatar
Rep:178
went to the alignment shop today...big song and dance. they put it on the rack and everything was off. they insisted that unless i could give them "new specs" to go by cause it was lowered, they couldnt do anything. they told me the factory specs were useless cause it was lowered. the only thing they agreed to change was the toe. funny thing is that it fixed my problem.
Old 01-15-2010, 09:21 PM
Resident Technician
Rep:1915
Those guys are just plain wrong. Factory specs still apply as long as they can be brought within tolerance. Sounds to me like they just didnt want to fight with the upper control arms to get the caster and camber right. Did you happen to get a copy of the final settings?
Old 01-15-2010, 09:46 PM
curt4816's Avatar
Rep:178
they didnt even want to try to do anything with it. all they would do was the toe setting and they didnt give me a printout
Old 01-15-2010, 09:54 PM
Resident Technician
Rep:1915
Find yourself another alignment shop. If the camber is out excessively it will cause premature tire wear on the edges. Any moron with a 24mm wrench can set the toe but it takes an alignment specialist to get it right.
Old 01-15-2010, 10:06 PM
curt4816's Avatar
Rep:178
i intend to, thanks again randy!
Old 01-16-2010, 12:37 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Sooooo... Can we see your truck? Pics please.
Old 01-16-2010, 12:50 AM
Rep:3347
agreed, all this and still no pics!
