Transmissions - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Old 01-20-2010, 10:51 PM
Dodgem's Avatar
Dodgem Dodgem is offline
Vehicle: 05 4.7L 1500 2WD
Trim Level: Quadcab
Dodgem is on a distinguished road
Send a message via Yahoo to Dodgem
After I drop old pan and replace with new one. What about running synthetic in the transmission? How do you get t-fluid out tq converter without separatin the two? Or mixing it is ok?
k&n drop in, airraid intake tube, nerf bars, bosch plat single grd, fiberglass cover, 90k
Old 01-20-2010, 11:11 PM
Resident Technician
Rep:1915
The fluid in your trans is synthetic from the factory. If you want to change all the fluid, you'll have to have it hooked to a flush machine that will pump out the old and replace it with new.
Old 01-21-2010, 11:48 AM
Dodgem's Avatar
Trim Level: Quadcab
As long as its ATF4. Any particular brand or does it matter? Vavoline, castrol, mobil1
Oh yeah, is adding a quart of lucas transmission fluid overkill? I've been told to add because of high milege. But as long as you keep fluids at correct level you should be good right?
