99 5.2 cat delete - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 11-29-2016, 09:10 PM
JMIL199 JMIL199 is offline
Vehicle: 2015 Ram 2500
Color: Granite crystal
Engine: 2015-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 865lb/ft (Aisin ASC69RC Automatic)
JMIL199 is on a distinguished road
Default 99 5.2 cat delete
If I wanted to get rid of the cat....can I get rid of my o2 sensors and have my truck tuned to run well without the sensors and cat? My county does not do emissions testing, so not exactly breaking a rule.
Any and all help appreciated.
Old 11-30-2016, 01:21 PM
striker2237's Avatar
striker2237 striker2237 is offline
Vehicle: 2003 Ram Laramie 4x4 3.55 LSD
Trim Level: 6.7L/408CI+NOVI 2000
Color: Bright Metalic Silver
Rep:185
striker2237 has a spectacular aura aboutstriker2237 has a spectacular aura about
No you need the sensors (the front ones anyway) but the rear one will have to be fooled into thinking there a cat there.
Mods: OEM tonneau cover+bug deflector+bedliner+floormats+hitch light+fuel door, Stubby antenna, 900CA AGM battery, Silverstar lights, Front window tint, Cabin filter, Bilstein 4600s, Kicker stage 1, Rear wheel liners, Mopar valve covers+breather, Pacesetter wrapped headers, Custom midpipe, Magnaflow X-pipe+custom axleback, SSBC front brakes+Powerstop rear, Moog front suspension+hubs, Maval custom rack, Borgeson steering shaft, Stainless steel brake lines, Hellwig front/rear sway bars, Poly bushings, Custom springs, Hydroboost
Old 11-30-2016, 01:23 PM
Hmm. How does one fool the sensor behind the cat?
Old 11-30-2016, 02:58 PM
Rep:185
Get a mini cat or tune it to ignore it.
Old 11-30-2016, 03:02 PM
Thanks for the input. Would a regular plug in tuner handle that tuning?
Old 11-30-2016, 06:31 PM
Rep:185
Honestly you would have to check with that particular tuner
Old 12-01-2016, 05:45 PM
rm-indy rm-indy is offline
Vehicle: 1996 Dodge Ram
Trim Level: Indy 500
rm-indy is on a distinguished road
They still make pipes that look like Cats and that will have ports for the sensors
Old 02-05-2017, 12:27 PM
FDRam01's Avatar
FDRam01 FDRam01 is offline
Vehicle: '01 Ram CC
Rep:13
FDRam01 is on a distinguished road
Jegs has a catless y pipe. I have it on my 01. What I did the spark plug anti fouler trick. Google it and it will explain the process. No issues with check engine lights.
Old 02-10-2017, 05:21 PM
2ndgenguy's Avatar
2ndgenguy 2ndgenguy is offline
Vehicle: 1997 dodge ram
Trim Level: L T w/ AC
Color: emerald green metalic
Rep:20
2ndgenguy is on a distinguished road
Depending on tuner options the only available one I could find for my 97 was the hypertech. Did nothing. So waisted 400 bucks there. Just spent another 800 to do it properly. My advice save and get a proper ECM programmer. It will save you in the end. Plus way more options to play with.
2012 6.7 Cummins Tuned and Deleted - H&S MiniMaxx, Flo Pro Exhaust, and Sinister EGR Delete brandonjansen Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 78 01-23-2017 02:23 PM
Muffler Swap or Delete?? Jason Cherry Exhaust 3 02-07-2015 09:41 PM
Flowmaster 10 vs Muffler delete ksgries Exhaust 19 12-30-2013 01:06 PM
waht is EGR and should I delete? farmall Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 10 09-08-2011 09:18 PM
EGR codes after a DPF delete? lancinator Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel 1 09-27-2010 09:34 AM
