Old 01-13-2010, 02:33 PM
justsomeguynia justsomeguynia is offline
Vehicle: 2005
justsomeguynia is on a distinguished road
Default Maintence
I just bought an 05 Hemi Big Horn with 24,000 miles. Coming up on an oil change. Gonna change her out with Amsoil 5w20. 7 quarts right? Someone told me to change the coolant out at 5 yrs or 100,000 miles. Is this really neccesary? I think my book says to change the plugs out at around 30,000. Is this absoulutley neccasary also? Also is there a drain plug in the tranny? Or do you have to drop the pan? Would like to switch to synthetic in my tranny and transfer case. Since weve had some -25 to -30 degree nights. Make it easier on her a little bit.
I went from a Dakota to a Ram and im loving it.
Thanks guys.
Tyler in Iowa
Old 01-13-2010, 03:57 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
7 is correct bro... plugs are a good question I have 34 on mine and i will be changing shortly...
Old 01-13-2010, 06:41 PM
Resident Technician
Rep:1915
Based on my work experience, I'd change the coolant at around 4 years. Most of the ones I see at 5 years already have deposits forming in the cooling system. Changing the plugs at 30k is a good idea to maximize performance and fuel economy. It's not like the engine will stop running at 30k if you don't. The fluid in your 545RFE transmission and transfer case is already synthetic as are your diff fluids. Following the maintainence schedule in your manual is the smart way to go.
Old 01-13-2010, 11:23 PM
I would recommend to do it all Tyler . Get rid of the factory coolant and install new with distilled water . Trans fluid , drop the pan , put in a new filter and refill with Amsoil . Do the transfer case also with Amsoil . Plugs are a good idea also . Look into a set of NGK's .
Old 01-14-2010, 12:18 AM
supercharged03hemi's Avatar
supercharged03hemi supercharged03hemi is offline
Vehicle: 2003 ram 1500
Color: graphite
Rep:35
supercharged03hemi is on a distinguished road
Send a message via Yahoo to supercharged03hemi
^^^I agree
Old 01-14-2010, 02:26 AM
Rep:3322
Well, you'll like the Amsoil, I know I do. If it's new to you, then I'd probably switch everything out myself just so I knew what was in there.
Old 01-14-2010, 10:19 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Rep:209
Ditto! Start fresh as soon as you can so you know (from this point on) exactly what's been done to it.
Old 01-14-2010, 10:37 AM
jkulysses jkulysses is offline
Vehicle: 2007 Ram Quad Cab
Trim Level: 2500 4x4 HEMI
Rep:68
jkulysses will become famous soon enough
I need to do these things too but when I drop the tranny pan and change the filter how do I get all the fluid out of the lines that go to my tranny cooler and all that? I also have the 545RFE at least I think I do it's a 5 speed I do know that much. I also have the positraction rear end so does that fluid need to be changed more often to keep everything working properly?
Old 01-15-2010, 11:51 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I have lsd so I usually change my rear end fluid every other year (I have an 05 with 175k miles on her...also with Amsoil), the last time I did my tranny i disconnected the cooler line near the radiator and put a bucket by there, started my truck and it pumped a quart or 2 out, reconnected lines and topped the fluids off..
Old 01-15-2010, 08:03 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Yup, if you're obsessive compulsive as me then you do things a little bit before the normal interval, especially if your vehicle is a severe duty vehicle.
By the way, thanks for the info. I never knew that Dodge uses synthetic fluids in our transfer cases and diffs.
