Throttle Body Cleaning Procedure - Page 5 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Knowledge Base
Diesel Forums!
Dodge Caliber
Place your Ad Here!
Old 07-10-2011, 10:38 PM
Leadfootluke Leadfootluke is offline
Vehicle: 1998 Dodge Dakota
Rep:276
Leadfootluke is a jewel in the roughLeadfootluke is a jewel in the roughLeadfootluke is a jewel in the rough
Originally Posted by The Codes View Post
How is the IAC removed? and cleaning it will result in smoother idle? hoping to do the tb and IAC both tomorrow. might just do the tb mod while I have it off as well.
There are just a few screws to remove it. What happens is the IAC [idle air control] opens and closes to establish the proper idle. Carbon and other deposits build up and make it sticky, so the valve [acts just like a plunger] doesn't operate as smooth as it could. So clean the plunger on the IAC with chemicals that do not eat away the o-rings or other parts of the assembly and do a good job cleaning the port where the IAC resides. A LOT of buildup occurs in there too.
If you did it already, how did it go?
Old 07-10-2011, 11:29 PM
The Codes's Avatar
The Codes The Codes is offline
Vehicle: 1998 Dodge Ram
Rep:44
The Codes is on a distinguished road
didnt end up doing it already, my girlfriend is going out of town tomorrow so I needed my truck to get us around all weekend..but while she is gone I will have some time to myself to do it so where exactly is the IAC located on my magnum engine..? sorry..really need to invest in a service manuel..
Old 07-10-2011, 11:46 PM
Rep:276
It is attached to the throttle body and it looks like this. Just unbolt it and pull it out.
Old 07-11-2011, 12:20 AM
The Codes's Avatar
Rep:44
oh okay sounds easy enough. as for the throttle body cables on the left, do those just slide of or is there a special way to get em off? I see where it unbolts but I noticed in another thread a guy broke one of the clips on the cable off and I was just checking to make sure theres no special way to take em off
Old 07-11-2011, 11:13 AM
Rep:276
They are just C-clip style where you slide them forward before you take them off.
Old 07-11-2011, 11:24 AM
The Codes's Avatar
Rep:44
alright thanks alot, will do this today if the rain holds off
Old 08-12-2012, 01:32 PM
rjburgan rjburgan is offline
Vehicle: 2003 Dodge Ram 1500 4X4
Color: Dark Gray
rjburgan is on a distinguished road
Hey RamTech..newbie here. So is this Procedure OK for the 2003 Ram 4.7? I have no idea if mine is electronic throttle controled or not... I am having this whole problem of truck dies at low idle. Would this be the best place to start on the problem?
Thanks
RJ
Old 08-12-2012, 01:46 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
The easiest way to tell if it's electronic throttle controlled is to look at the throttle body. If it's got cables going to it it's cable controlled. If the throttle body is electronically controlled (some call it "drive by wire") it's electronically controlled. If it's got an APP (Accelerator Position Pedal) it sends an electronic signal to the throttle body to correspond with the pedal's movement.
Kind of like an old steam ship. Captain moves the handle and it sends a signal down to the engine room. Engine room workers make it happen. Man I guess this isn't new technology after all.
If it is electronic do not move the butterfly manually.
Old 01-29-2013, 08:31 PM
northgaFTM northgaFTM is offline
Vehicle: 1988 Dodge D100
Trim Level: Custom
northgaFTM is on a distinguished road
Cool
do you think this could be my problem.. i just cleaned the tank, replaced the fuel pump, strainer, and the fuel filter... it's been doing really good until today, we went up a really steep hill and it pretty much lost all power... ater that it starting acting crazy... i you press the pedal to the floor, it backfires and stalls, unless you are sitting at idle, it does ine sitting at ile.. but chokes out when you stop... you really can't get it above 35-40 because no matter how hard you try to ind a happy medium with the pedal it will not happen...
Old 02-05-2014, 04:02 PM
Ceace Ceace is offline
Color: Brilliant Black Pearl
Ceace is on a distinguished road
Removed my TB and cleaned it this pass weekend. VERY simple and there was a lot of buildup. But now it looks almost brand new.
