Overheating - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-14-2010, 03:42 PM
doofusone doofusone is offline
Vehicle: 2003 Dodge Ram 1500
Color: gold
Rep:24
doofusone is on a distinguished road
Send a message via Yahoo to doofusone
Default Overheating
Been having problem with anti-freeze flowing out of reservoir while driving or if I rev the engine, you can see it flowing out onto engine as it goes back to idle. Eventually it starts to overheat as liquid empties out. I tried replacing thermostat thinking maybe that was the problem, but still got same issue. Anyone have any ideas??? Dont really want to pay an arm and a leg to a mechanic for something I can fix myself. No water mix in oil and no unsual smoke from exhaust.
Old 01-14-2010, 06:46 PM
Could be a thermostat or maybe a head gasket .
Old 01-14-2010, 09:46 PM
Resident Technician
Rep:1915
Did you try replacing the cap?
Old 01-14-2010, 11:18 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
i had a simular problem with my mothers car i had to replace here coolant reservoir it was a slight crack on the part the hose connects two but again that was a car i hope this helps
Old 01-14-2010, 11:56 PM
Color: gold
Rep:24
someone told me it may be the clutch on the fan. At idle it doesnt overheat. Even after sitting at idle for 15-20 minutes, temperature never goes up. I know when I first got truck fan sometimes makes a unsually loud blowing noise but then quiets down after I rev engine a few times. I didnt think nothing of it, until a co-worker mentioned it. I dont think its a head gasket, under pressure there are no leaks, even around water pump
