Mud flaps for 2010 ram 1500 - Page 2 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-18-2010, 01:01 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Hey Fuzznutts, they look pretty good. I think I'll be ordering a set.
Old 01-18-2010, 01:11 AM
HoustonHemi's Avatar
HoustonHemi HoustonHemi is offline
Vehicle: 1492 Santa Maria
Color: Hot pink
Engine: 1981-1987 225ci (3.7L) Slant-6 95hp
Rep:135
HoustonHemi will become famous soon enoughHoustonHemi will become famous soon enough
I just visited the MFG's website. They look super-easy to install. How was your install, Fuzz?
Old 01-18-2010, 10:28 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Last pair I had were OEM installed by the dealer. I had to take them back off and put a bead of silicone between the fender liner and the flap though. Without it, mud and water would run down the fender well liner, between the liner and the mud flap and then run down the backside of the flap! I don't mind a bid muddy streak on the front side of the mud flap - That's what it's there for! But always having these unsightly streaks down the back had to go!
Old 01-18-2010, 12:51 PM
Fuzznutts's Avatar
Fuzznutts Fuzznutts is offline
Vehicle: 2010 Dodge Ram 1500 QC
Trim Level: Bighorn Edition
Rep:25
Fuzznutts is on a distinguished road
For the rear you remove 2 current screws that hold your fender well liner in, place the flap in place and reinstall the screws. That's about as easy as it gets!
For the front, you rotate your steering wheel to full lock, turn off the truck, remove 1 existing screw that holds the fender well liner in place, put the flap in position and start the existing screw back in its hole, add an additional screw with washer and nut that is provided with flaps in the next higher hole that is already there from the factory and tighten both. The kit includes one more set of hardware for each front if you choose to drill one additional hole towards the bottom of the liner and inboard about 4 inches to stiffen the flap. I did it and you still don't have to take the tire off using a regular 3/8" drill.
Let me know if you have any questions.
Fuzznutts
Old 01-18-2010, 02:24 PM
Color: Hot pink
Rep:135
Sounds way easier than the 'universal' flaps, Fuzz!
Good point about the silicone, Yard. I'll have some handy when the Husky's get here!
Old 01-18-2010, 03:59 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
I have tech shield on my 08 they are great
Old 08-26-2010, 10:06 PM
wecoyote's Avatar
wecoyote wecoyote is offline
Color: Light Greystone Pearl
wecoyote is on a distinguished road
So, how did the husky's go in? I am curious if you really do not have to drill.
Wile E. Coyote - Windsor, ON
2010 Dodge Ram 1500 4x4 SXT Crew Cab
Old 08-26-2010, 11:21 PM
Color: Hot pink
Rep:135
They require 'minimal' drilling,,,
I drilled (1 hole) through the plastic liners to secure the most 'inboard' edge of the flap. I may have drilled a couple more holes, can't remember, but they do utilize some of the existing OEM screws,,, That's nice as you don't have to worry a lot about getting the driver side flap on the same height as the passenger side,,,
One additional benefit of the Huskys is they also include some clear 'film' that goes on between the outside edge of your fender and the flap itself,,, helps to make sure the flap doesn't rub up against your paint,,,,
Old 08-27-2010, 12:53 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I gotta get me a set of these. I noticed a couple rock chips on the passenger door. It is only in the clear, but it has less than 500 miles on it! Can I buff those rock dings out? The paint appears to be in tact, but there is a small divet there from the rocks.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 08-27-2010, 05:30 PM
Pull Ya's Avatar
Pull Ya Pull Ya is offline
Vehicle: 2013 Dodge Ram Laramie 4x4
Rep:365
Pull Ya is just really nicePull Ya is just really nicePull Ya is just really nicePull Ya is just really nice
I don't mean to hijack the thread but has anyone tried the 3M invisible bra material on the lower part of the 1/4 panel to stop the rock chips in the paint. I think it comes in 6" wide rolls.
Jay
Just cause it's loud doesn't mean it's fast and just cause it's shiney doesn't mean it's protected. Remember, going fast costs money, so how fast do you wanna go?
Semper Fi Forever
