Tire size question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 01-14-2010, 10:23 PM
curt4816's Avatar
curt4816 curt4816 is offline
Vehicle: '11 Dodge Ram Crew
Trim Level: Laramie 4X4
Rep:178
curt4816 has a spectacular aura aboutcurt4816 has a spectacular aura about
Default Tire size question
Buying 24 X 9.5 inch wheels. what size tires do i get? i dont want them to be too low of a profile. the guy who i bought the wheels from recommended a 315/35/24. i kinda think it might be too big. i dont want to look like i have off road tires either. im doing this transaction over the phone (amazing deal, by the way) so i have nothing to look at. my truck is lowered 2/3, if that helps. i would love to see a pic of this size wheel and tire if one was out there.
for those wondering what i got,.... 24" KMC "Slide"
Mods: H&S Mini Maxx w/ egr and dpf deletes
Old 01-15-2010, 01:30 AM
Rep:3347
I'd recommend 285/45/22, they are low profile but they fit quite nicely. Checked out Tirerack and they say the same size. If you've got a 2/3 drop then I'd recommend the low pros or you'll run into rubbing issues on the inner fender unless you've had them rolled in.
Old 01-15-2010, 08:23 PM
curt4816's Avatar
Rep:178
so a 305/35 definitely wont work, huh??
Old 01-16-2010, 01:45 AM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
google tire size calculator, there are several good ones. Put in your current tire size, and then chose 24" and it'll spit out a close match. If you dont want a lower profile tire, why 24"....Was your OEM size 275/60-20? If so a plus 4 would be a 285/40-24
Stock Tire - 275/60R20
Tire 1 - 285/40R24
Section Width: 10.82 in 275 mm
Section Width: 11.22 in 285 mm
Rim Diameter: 20 in 508 mm
Rim Diameter: 24 in 609.6 mm
Overall Diameter: 32.99 in 837.94 mm
Overall Diameter: 32.97 in 837.43 mm
Sidewall Height: 6.49 in 164.84 mm
Sidewall Height: 4.48 in 113.79 mm
Radius: 16.49 in 418.84 mm
Radius: 16.48 in 418.59 mm
Circumference: 103.6 in 2631.4 mm
Circumference: 103.5 in 2628.9 mm
Revs per Mile: 630.4
Revs per Mile: 630.8
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.0 mph 100. km/h
Speedometer Difference: - Speedometer Difference: 0.063% too fast
Diameter Difference: - Diameter Difference: 0.07%
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
