Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 01-15-2010, 11:23 AM
dad22153 dad22153 is offline
Vehicle: '99 Dodge Ram 1500 4WD
Trim Level: Lariat Extended Cab
Color: White with silver lower body
dad22153 is on a distinguished road
Send a message via Yahoo to dad22153
Default Possible vacuum or electrical issue with heater/AC ducting
I was driving the other day, and had my heater blower set to high, with the duct setting set to winshield and floor. It seems to work fine, when driving normal, but as soon as I accelerate, I notice that the blower seems to slow down, and it might be trying to go to different duct option.
Has anyone experienced a similar problem? Any advice would be appreciated.
Dave
Dave
Old 01-26-2010, 10:11 PM
sjarrett71 sjarrett71 is offline
Vehicle: 1997 Dodge 1/2 ton 4x4
Trim Level: SLT \
Color: Maroon/Gray
sjarrett71 is on a distinguished road
The way I understand it there are 2 vacuum check valves in the engine compartment near the firewall. They are small and the parts guy should know what you want. I just walked into the Dodge dealer and ordered two for about 9.00.
97 Dodge 1/2 4x4, Laramie SLT, 360/Auto, Single cab/Long bed
Old 01-26-2010, 10:17 PM
Yeah sounds like you have a vacuum problem . I believe the vacuum source is tapped into the brake booster (?) Might have a bad check valve .
Old 01-27-2010, 08:43 AM
Thanks for the advice guys,
I'll check out the vacuum lines and try to locate the check valves.
Dave
Dave
