Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Knowledge Base
Old 01-16-2010, 06:10 PM
Rep:1845
Default Center Your Steering Wheel - R&P Steering
This is a fairly old trick to recenter your steering wheel if it's off a bit and you aren't getting any uneven wear on your front tires. Granted an alignment is the best way to go but this works for us thrifty people.
The first step is to take a paint marker, tire crayon or something similar and make two marks on each side of the truck, one on the inner tie rod and one on the outer. Then loosen the jam nuts with a 24mm wrench.
If your steering wheel needs moved to the left, rotate the inner ends toward the front of the truck on both sides. If it needs moved to the right, rotate the inner ends toward the rear of the truck. I recommend moving them no more than 1/8 of a turn at a time to avoid overshooting the center. By using the reference marks and turning the inner rods equally, you won't throw off your toe setting. Hold the inner rod with pliers or a wrench (depending on your style of inners) and tighten the jam nuts, then double check the reference marks because the inner rod will sometimes turn with the jam nut as you tighten it.
Old 01-16-2010, 11:30 PM
I use to do that on my road tests after a alignment was done . If the steering wheel wasn't perfect , it would be when I got back .
Old 01-16-2010, 11:31 PM
Rep:1845
That's what I do as well. Most machines can't get steer ahead right because of the inevitable play in the steering.
Old 10-08-2011, 04:45 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Just curious if this will work on a 2010 ? I heard there was some kind of sensor in the steering column that's used for centering it, any truth to this or is it all mechanical ?
Old 10-09-2011, 01:43 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
So I performed this adjustment and my steering wheel is now straight. I just have a couple of followup questions. First, please confirm that both inner ends turn the same way to keep the toe setting the same? What I found was on the inner rods the aligned marks are now on the top for 1/4 turn on each. Second question is how much force to put on the jam nut, I'm guessing I put about 30 ft/lbs on them. This was actually a pretty easy adjustment to make. Thanks to RamTech once again !!!
