Old 01-18-2010, 01:31 PM
ram1hemi's Avatar
ram1hemi ram1hemi is offline
Vehicle: 2007 Dodge Ram 1500 4x4 QC
Trim Level: Big Horn SLT Hemi
Color: Grey
ram1hemi is on a distinguished road
Default 07 1500 4x4 Tow Hooks question
Tow hooks for 2007 1500 4x4 are on one single plate. Does anyone know the length of that mounting plate? I'm trying to figure out how much gap will be on each side with the platic bezel, currently in place, removed, or if there will be enough fasteners left on the bezel after cutting to fit the hooks/plate to hold it in place?
Ideas or thoughts anyone?
Old 01-18-2010, 02:24 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
does the front spoiler need to be cut? how much is this system?
Old 01-19-2010, 11:50 AM
ram1hemi's Avatar
Color: Grey
The spoiler is not affected. Tow hooks mount through the plastic insert piece on bumper.
Old 01-19-2010, 12:40 PM
Rep:1885
Some of the factory units come without the mentioned plastic piece and hooks already installed. I think it would be fairly simple to cut the plastic out if you wanted to keep it in place. I just looked at an '08 2500 but it's a different setup than what you're describing. The factory uses individual hooks that are bolted to a bracket on the frame. If I can get my hands on an '07 1500 today, I'll see if I can get you an answer.
Old 01-19-2010, 12:47 PM
Rep:1885
I just found a truck with the hook setup you described and the width measured at 30.5 inches. The plastic piece is not installed on this truck and it doesn't look like it would be doable from what I'm seeing but where there's a will...
Old 01-19-2010, 01:13 PM
Rep:2657
this comes fron another dodge forum & its an 2003 model, home made hooks installed with pix....you have to play with the website below, to make it work
www. dodgeforum. com/forum/3rd-gen-ram/206189-homemade-tow-hooks-done-with-pics.html[/url]
you may also want to view this site
http://www.amazon.com/gp/product/ima...tomotive&img=0
wish you luck
Old 01-20-2010, 07:26 AM
ram1hemi's Avatar
Color: Grey
thanks alot for your feedback Randy and GTYankee. Will order the set, and see what I can make work from there if I don't like the look on the sides of the hook plate.
Old 03-01-2010, 07:54 PM
ram1hemi's Avatar
Color: Grey
Thanks for everyone's feedback. I finally got the hooks installed .They do not extend past the bumper as far as I think they should...but will work if needed. I did get the plastic insert in the bumper, which is normally just removed, cut to fit around the hooks and reinstalled. It was a simple job using a wafer wheel on a pencil grinder, and the original fasteners lined right back up.....be aware though the plastic fasteners are a bear to get out,,,don't be afraid to pull. Reinstalling the plastic piece is well worth the time, because it gives you a much cleaner look.
Old 03-01-2010, 08:08 PM
ScatPak07's Avatar
Rep:970
That sounds like a cool little mod. Where did you order the hooks from? I wouldn't mind getting a set on my front end as well
