Old 01-18-2010, 03:01 PM
Quiet Lunatic's Avatar
Quiet Lunatic Quiet Lunatic is offline
Dodge Ram Forum - Dodge Truck Forum - Dodge Ram Club
Vehicle: SRT-10
Rep:434
Quiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enoughQuiet Lunatic will become famous soon enough
Default New Lights
Got tired of dim bulbs so bit the bullet and got some new Silverstars. Followed the Owners Manual for changing bulbs and seriously thought about shooting my truck. Removed two screws from each side and then nut with access through wheel-well. Book says to pull straight out out on headlight assembly but mine didn't want to come out and I was afraid to pull or pry to hard for fear of breaking somethling. Gave up and attacked from inside hood, carefully removing bulb assembly and then old bulb. Then, carefully with rubber gloves and paper towels I installed the new bulbs and, lo and behold, the lights work. As soon as it gets dark I will go outside and play.
Old 01-18-2010, 03:04 PM
Rep:1885
I have the Silverstar Ultras and I love them. There's a big difference in the width of the beam and brightness. I even cranked up my low beams just a tad when I put mine in.
Old 01-18-2010, 06:11 PM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
Silverstars work great but from my personal experience they're too expensive for such a short lifespan. I'd sooner spend the money on PIAA Extreme White Plus, which cost about double but have lasted far longer than anything I've used so far, short of the HID upgrade I did on my Audi.
As far as replacing the headlights, it's pretty easy and you shouldn't have difficulty. I'd say they're easiest done from up top rather than from underneathe. Passenger side is easy 'cause there is nothing in the way. Driver side you simply remove the fusebox cover to gain more access. Just be sure not to get your fingerprints on the bulbs.
Old 01-18-2010, 10:05 PM
I push the skinny pedal
Rep:3277
If you want to pull the assembly, after removing the 2 torx bolts and the 10mm behind the front wheelwell insert. After that I use a flatblade screwdriver wrapped in a rag and gently pry the top corner of the assembly. Only have to move it 1/4" and it pops out no problem. I have probably removed my assemblies about 20 times by now with all the mods I've done and I have no scratches to the paint OR damage to the socket the ball fits into.
Kurtis
