Old 10-28-2011, 02:34 AM
logtice's Avatar
logtice logtice is offline
Vehicle: 2001 Dodge Ram 1500 5.2 V8
Trim Level: base
Rep:17
logtice is on a distinguished road
Default replacement dash!
Well ive posted a few pics of my dash.... so say the least ANYTHING would be an improvement, so i decided to go to the junk yard and see if i can find a replacement! i looked thru 18 second gen Rams and no dashs! coming to the last one, i opened the door and was amazed to find a dash in pretty good shape! it was only in 3 diff pieces so i decided to give it a try! I think it came out pretty good! just have to get a dash cap or a carpet now! ill post more pics!
this is the dash i had in the truck haha
after i removed all the old dash
i used plastic locktight and JB quick to piece it together!
and the other.
Old 10-28-2011, 02:42 AM
logtice's Avatar
Trim Level: base
Rep:17
the final product!
i did have to do some plastic welding, well alot haha you can still see the cracks and such, but the main reason why i did this was to get a dash cam for it. before there was nothing for the cap to acctually glue on to.
opinions would be nice!
Old 10-28-2011, 02:58 AM
Rep:2616
I will say that it looks much better
you could use some of this & make it look just a bit better
PERMATEX® Pro Style Vinyl and Leather Repair Kit
A complete professional kit with plug-in electric heat iron to make pro-style repairs. Contains: professional electric heat tool, 7 OEM color compounds, clear vinyl adhesive and filler (net .34 oz.), grain pattern paper, metal spatula, plastic dashboard hardening powder.
Suggested Applications:
Vinyl and leather upholstery, dashboards, vinyl tops, marine upholstery, luggage.
Prod 81781
$20.00
Old 10-28-2011, 01:53 PM
Dieselkiss's Avatar
Dieselkiss Dieselkiss is offline
Vehicle: 99 Ram 1500
Trim Level: ST - Very Base Model
Color: Red with grey
Rep:48
Dieselkiss is on a distinguished road
Default ..
How much hassle is that top piece to get out?
About a year ago I fitted central locks and electric windows to mine and had originally wanted to remove the top part of the dash to do it. I couldn't work out how to get it out so ended up just removing all the front sections of the dash which gave me enough room to run the looms through.
my dash now has some serious cracks in it and I've considered either putting one of the dash caps you can buy on it or just replacing the dash top completely with a new or used good one. It depends how it's done and how much hassle it is, so any head's up on that??
Old 10-28-2011, 02:55 PM
logtice's Avatar
Trim Level: base
Rep:17
well the hardest part about removing the dash, there are like 5 little strews attached thru bracets... but the are goin into the dash from the firewall! the dash from factory is put in as one complete unit, cluster radio glove compartment and dash...
i could not find a way to remove those screws without destroying the dash, so i just reached up there with a pair of snips and broke the plastic the screws go into, which didnt crack the dash anymore just removed those screws
Old 10-30-2011, 01:39 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
what about pass air bag? I want to get new dash. fix it once and for all.
Old 11-01-2011, 05:10 PM
logtice's Avatar
Trim Level: base
Rep:17
the air bag is held in with 5 or 6 screws, just pull out the glove box there is a plastic trim piece around the latch, remove that too. 2 big screws under the bottom and 3 across the front. you will also have to remove the latch for the glove box, 2 screws.
IMPORTANT* make sure and disconnect ur battery before you start messing with the air bag! dont want that shit blowing in you face! =]
dash
1994 CTD Dash Replacement johnny0874 Body & Interior 15 04-09-2011 11:22 PM
03 Ram Dash defroster grille replacement brock1sampson9 Body & Interior 4 01-16-2011 12:05 AM
Anyone successfull with getting a dash replacement angelicshadows Body & Interior 4 12-09-2010 12:58 AM
Newbie needs dash replacement for 97 Ram Headhunter843 Newbie Checkin! 12 10-16-2010 02:38 AM
Dash removal/ Heater core replacement Trishafer Heating & Cooling 6 02-25-2010 07:23 PM
