Old 01-19-2010, 02:50 PM
Rep:2657
its well worth spending about $80 for a battery charger, especially if you have cars, trucks, motorcycles, snow mobiles, quads & neighbors in need
i personally have 2 of the 2/10/50 amp chargers & 1 portable jump start unit from
http://store.schumachermart.com/se-1052.html
Old 01-19-2010, 06:02 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Sounds like you need to bring your battery to a full charge. Jumping it and the GPS plugged in will just drop the battery down again.
Old 01-20-2010, 03:48 AM
deanthecrabman's Avatar
deanthecrabman deanthecrabman is offline
Vehicle: 2001 Ram 1500 Quad 4WD 5.9
Trim Level: Quad cab
Color: Garnet red
Rep:202
deanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura aboutdeanthecrabman has a spectacular aura about
Wouldn't ia GPS have to go a long time to pull a car battery down to 6V? Anyways, always good to have a battery charger around. I've had to put new batteries on the charger before to wake them up if they've been sitting on the shelf a while. First thing would be to have that battery load tested to make sure it will hold the charge. If the battery is bad, nothing else will work. BTW, did you look at the cells when you added the water? Had one die on me, water in one cell was black. Knew right away needed a new battery.
Old 01-20-2010, 08:15 AM
Rep:1909
That depends on how much amperage it's drawing and the state of the battery when it was first plugged in.
Old 01-20-2010, 11:01 AM
npoe25's Avatar
npoe25 npoe25 is offline
npoe25 is on a distinguished road
Wouldnt the alternator recharge the battery while im driving?
2001 Dodge Ram 1500 5.9 V8 Magnum
Old 01-20-2010, 11:14 AM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
It will charge enough for surface charging, but not enough to bring it back to a full state
Old 01-20-2010, 01:01 PM
npoe25's Avatar
Well lucky for me my neighbor just so happened to have a charger! I just put it on charge
Old 01-20-2010, 03:09 PM
bones64's Avatar
Rep:659
Hey there. Just checking back to see how you are making out. Is everything good? Need anymore help? Let us know. All the best.
Old 01-20-2010, 04:34 PM
npoe25's Avatar
Yup everything is good. Just charged it up and its purring like a kitten. Thanks for all your help fellas. I'm sure I'll be on here alot more often now.
Old 01-20-2010, 04:37 PM
Rep:1909
You really should set it up for an overnite trickle charge (2-5 amps) to put a good charge back on the battery.
