Old 01-09-2010, 12:44 AM
Ray's Avatar
Ray Ray is offline
Vehicle: 2010 Dodge Ram 1500 Crew Cab
Rep:45
Ray is on a distinguished road
Default Regular gas in a 2010 ram with a hemi?
I have a 2010 ram 1500 with the 5.7 hemi. The dealer told me it was ok to use regular gas. Is anybody else using regular gas or going with a higher grade
Mods:Mopar fiber glass Tonneau cover,Nerf Bars,Bully Hitch bar,husky mud guards,stubby antenna,Edge guards,weather mats,20%tint all around+windsheild,lisence plate covers,Upgrage to REN w/back up cam,Magnaflow 18, putco bulbs,LED interior/plate bulbs,viper smartstart
Old 01-09-2010, 12:50 AM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
use what manual recomends unless you have it tunned otherwise. 89 octane is for stock tune
OLD TRUCK
NEW truck soon to be here
Old 01-09-2010, 01:11 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
recommendation is to run 89 octane, but you can run 87 with no issues. I'd avoid 85 unless you're FlexFule equipped, which I don't think the 5.7Ls are, only the 4.7Ls
It's a little pointless to run higher octane unless you're doing a cleaning run OR are running a tuner that requires a minimum octane rating.
Kurtis
Old 01-09-2010, 01:44 AM
MightyBlueRam's Avatar
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
I run 89. Sure the dealer tells you that you can run 87 but the manual says to run 89. If it was a tech that told you this then maybe you might do it. If it was a service advisor that told you, then I wouldn't listen. Some of those guys don't know jack and some do. I'm just saying, why give them any reason to say "oh but you didn't do what the manual said to do." I think there's a reason why they say to run 89.
Old 01-09-2010, 05:27 AM
Rep:1890
The reason for running higher octane is to prevent spark knock. The Hemi has a 10.5:1 static compession ratio. The PCM can compensate for lower octane by retarding the ignition timing but you could be giving up a bit on power.
Old 01-09-2010, 07:59 AM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
If this were to happen could you rectify the knocking and or reduced power by simply switching back to 89 octane?
What about the higher grades (91 or 94 octane). Does anyone run these and if so is there any benefit? (more power?)
Ambitious, but rubbish!
Old 01-09-2010, 08:23 AM
iRockCrawler's Avatar
iRockCrawler iRockCrawler is offline
Vehicle: 2009 Dodge Ram 1500
Color: Mineral Gray Metallic
Rep:44
iRockCrawler is on a distinguished road
Did you even read the post you quoted???
Higher octane does not equal more power.
I have been running 87 from day 1 with no issues. I have tried 2 consecutive tanks of 89 and could not feel or hear any difference with they way it ran so I stick with the cheaper stuff.
Old 01-09-2010, 08:24 AM
Rep:432
So if you are running at reduced power, would it be safe to say that the engine is working harder with less power and that leads to reduced mileage? I'm asking because if my thinking is correct then the money you save by using 87 is nulled by lower mpg. Is my assumption wrong?
Old 01-09-2010, 09:38 AM
Yes , if your running higher compression , you'll need higher octane fuel . If your running more timing (advanced) then stock (because of a installed tuner) it's quite possible you need a higher octane fuel . Both higher compression engines and vehicles with tuners on them are more susceptible to spark knock (detonation) . Detonation will ruin a engine . If you can get away with running a lower octane fuel so be it . But you better have a good ear . You don't want to ruin your engine . It is always a good insurance policy to run a little better fuel than required .
Rep:1890
I personally have only never noticed any kind of mileage difference. I've heard a lot of people argue the question you ask so I tired it myself in several vehicles over the years and never found any particular benefit. The quality of the fuel does seem to make a difference though. We have a place here called Cheap Gas and while it is a few cents lower per gallon, my truck doesn't seem to like it as well for some reason.
