Old 01-20-2010, 12:38 AM
Dodgem's Avatar
Dodgem Dodgem is offline
Vehicle: 05 4.7L 1500 2WD
Trim Level: Quadcab
Dodgem is on a distinguished road
Send a message via Yahoo to Dodgem
Default Drop in k&n vs cai k&n?
Would I see/feel any difference ?
Because I have a drop in k&n filter with an airraid intake tube.
Would it be a big difference going full cai or leave the way it is?
I felt an immediate difference when I install what I have now.
I still have stock exhaust.
k&n drop in, airraid intake tube, nerf bars, bosch plat single grd, fiberglass cover, 90k
Old 01-20-2010, 12:43 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I would go to the full K&N CAI. You may feel a difference in power depending on the application. But, you will most definately hear a difference in the engine!
You can direct greater volumes of air throughout a less restrictive passage to the engine with the conical filter... Which is why I'd make the switch.
However, I saw a demonstration showing just how big of a difference the K&N drop in has over the factory. They were doing it at NAPA. They had a ball in a tube where it would float due to the amount of air rushing in. To do so, the air had to flow through filters, the stock, and the K&N.
The stock filter barely had the ball floating. When the K&N filter was dropped in, it was about 3/4 of the way up!
Old 01-20-2010, 11:04 AM
will's Avatar
will will is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: slt/bighorn
Color: silver
Rep:43
will is on a distinguished road
I saw this to. However, the only real difference you will see is noise IMO. They don't really publish hp gains on drop in filters because every vehicles stock system is different, some being more restrictive than others. The hat or intake cover also keeps dirt out etc. It should have an intake port, so air is getting in. I don't think K&N would make one of thier filters flow better than another. IMO you have a great setup for what you need. Volant uses a closed box to, so as long as air is getting in, your good IMO.
OLD TRUCK
NEW truck soon to be here
Old 01-20-2010, 12:08 PM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
TRUE CIA will only start to pay of when you start adding real power mods headders, predator tuner, etc.. I have a hemi charger that I started with the K&N drop in and now have a CIA not anything I could tell in real power gain just sounds cooler.. add the predator and be willing to go to 93 on your gas and you can see improvement
Old 01-20-2010, 12:27 PM
RamTech RamTech is online now
Rep:1885
Engines are what in reality? Air pumps. Now think of where the point of highest restriction lies. Intake? Exhaust? Cylinder head? Cam profile? The more air you can flow into and out of the engine, the more power you can make. On stock 4.7 engines, the exhaust is generally where you find the most restriction because of the manifolds used. Swapping those out for a set of headers would give you a lot of bang for the buck. Couple that with a good CAI and tuner and you'll see a significant gain in HP and torque.
Dodgem's Avatar
Trim Level: Quadcab
So the setup that I have is ok because I dont plan on adding headers. But a freeflowing muffler and maybe a y pipe if that doesnt drop the mpg. I know the performance will pickup. Now on my 68 NY thats different performance only. Adding anything for performance is cool but dont want mpg to drop, gain is cool.
Old 01-20-2010, 01:12 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
You should nt loose any MPG buy going with a full C.A.I system. I have a Hemi in my 03 and i had a drop in K&N filter. I never seen any diff with mileage. I just made my own C.A.I with the K$N filter and seen no diff. in mileage as well. A bit more for performance but thats all.
