Old 01-21-2010, 07:33 PM
03dodge4x4 03dodge4x4 is offline
Vehicle: 2003 Dodge Ram Quad Cab
Color: Hunter Green
03dodge4x4 is on a distinguished road
Default Grinding noise in 4 wheel drive
When I was coming off the backside of my property I was in 4 wheel low and everything was running fine until I hit a little bit of a hole which was slightly rutted. There were these God awful grinding noises that began. I immediately stopped shifted to 2 wheel drive and gingerly pulled myself out. There were no sounds in 2 wheel drive, but when I shifted back into 4 wheel drive h & l the noises began again, but only if there was any resistance. Without any resistance there is no grinding noise and seems to operate fine. This noise is coming from the front transfer case and it really sounds like the gears aren't catching. What could this be?
Old 12-06-2011, 11:32 AM
barra340 barra340 is offline
Vehicle: 2001 Dodge Ram
Color: wht
barra340 is on a distinguished road
I have the similar issue. Mine is at the wheel making the noise though not the axle. Haven't diagnosed it yet.
Old 12-13-2011, 05:34 PM
Darek5.7's Avatar
Darek5.7 Darek5.7 is offline
Vehicle: 2009 Dodge Ram 1500
Rep:19
Darek5.7 is on a distinguished road
A friend had similar problem with his 99 chevy. turned out to be a bad bearing which in turn scraped up his pinion pretty good in his front diff. Had to replace them. He had shavings all in there. same happened to his left rear axle months later.
HIDextra 10000k, Hemi decals, Ultra Motorsports 17" rims and Bully Dog Triple GT
