Old 01-21-2010, 09:32 PM
ScatPak07's Avatar
Rep:970
Question 4.10 Gears
Hey guys! I wanted to know some more about the gear ratio thats currently in the truck. Now replacing the stock gears with a 4.10 ratio will help out quite a bit do you think?
The biggest question I have is, I have a programmer (DSP) now if I get the 4.10 gears put in will this affect the programme? Will they not work together, thats the question.
Any help would be great since I think this will be a new addition to my truck. What do you think of Motive Gears? Thats the company that I found that makes them heres the link http://moesperformance.com/index.php...oducts_id=1147
Old 01-21-2010, 09:34 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I am not too sure if it will affect the tuner, but if I had to take a shot in the dark, i'd say no it will not simply because that thing is so amazing at what it does.
What is the stock ratio? 4.10s will make it get up there a hell of a lot faster, thats for sure.
Old 01-21-2010, 09:48 PM
ScatPak07's Avatar
Rep:970
Yep thats why I want to do it haha. I'm going to look into this. Do you think I will need to get an LSD as well. Or is that more of a personal option. I would definatley want one too but $$$$$ always comes in
Old 01-21-2010, 10:24 PM
Rep:1909
If you already have the 3.92 gears it wouldn't be worth it.
Old 01-21-2010, 10:33 PM
DODGE4x4's Avatar
DODGE4x4 DODGE4x4 is offline
Vehicle: 2006 Dodge Ram 2500 4x4
Trim Level: slt big horn
Color: tan
Engine: 2005-???? 359ci (5.9L) Cummins ISB 610 24-Valve Diesel I6 325hp 610 lb/ft
Rep:82
DODGE4x4 will become famous soon enough
sorry not trying to thread jack, just one question. my brother said he would sell me the front and rear end out of his old truck to put in mine. its has 4:56 gears in it. what could i exspect out of my truck then? thanks a ton.
Old 01-22-2010, 01:46 AM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
... if you have 3.55's, the upgrade is to 4.10's.... 3.92's to 4.56's...
Old 01-22-2010, 01:54 AM
chefred112's Avatar
Rep:656
do you know what gears you have now? in either case, the performance difference will be noticeable..prepare for a smile
Old 01-22-2010, 08:39 AM
Rep:1909
A smile and even worse gas mileage!
Old 01-22-2010, 09:27 AM
DODGE4x4's Avatar
Color: tan
Rep:82
i figured just driving around town the mileage would improve, and on highway it would get worse, just a thought-lower gears means not as much of a struggle for the motor to turn my tires and wheels in a stop and go situation? and holding higher rpms on the highways means a little worse mpg?
Old 01-22-2010, 09:30 AM
wvcoolvinilla wvcoolvinilla is offline
Vehicle: 2011 Ram 1500 Outdoorsman 4x4
Trim Level: Outdoorsman - Rambox
Color: Black Crystal - Gray
Rep:83
wvcoolvinilla will become famous soon enough
4:56 if you are planning to go to a 35 inch tire.. 4:56 will put a bunch of strain on your drivetrain.. as Randy said if you have 3:92 you are there right now.. as for someone wanting to swap in some used gears not a good deal
