3.9L Intakes and Exhausts - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 3.9 Liter V6
Custom Dodge Ram Performance Mods - Engine - 3.9 Liter V6 Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 01-22-2010, 12:25 PM
canuckboy's Avatar
canuckboy canuckboy is offline
Vehicle: 1998 Dodge Ram 1500
Trim Level: None
Rep:114
canuckboy will become famous soon enoughcanuckboy will become famous soon enough
Default 3.9L Throttle Body and Exhaust
Throttle Body-
http://www.bouchillonperformance.com...ttlebodies.asp
2x48
Applications: 1992-2003 Stock to mildly modified 3.9L V6
The F&B 48mm throttle body comes with a new factory gasket, all new 18-8 stainless steel cap screws for your factory sensors, stainless steel hold down bolts, and the F&B billet seal nut for your airhat. This TB requires minor modifications to your factory airhat (Ram or Dakota). No modifications are required for aftermarket air inlet systems. The 48mm throttle body flows 660 CFM @25"
2x50
Applications: 5.2L and 5.9L V8, Modified 3.9L V6
The 50mm throttle body features a profiled 303 ss shaft with impregnated molybdenum finish. Comes with new factory gasket, all new 18-8 stainless steel cap screws for your factory sensors, stainless steel hold down bolts, and the F&B billet seal nut for your airhat. This TB requires minor modifications to your factory airhat (Ram or Dakota). No modifications are required for aftermarket air inlet systems. The 50mm Throttle body flows 760 CFM @ 25". Factory V8 throttle bodies flow 635 CFM @ 25"
Exhaust-
http://www.magnaflow.com/02product/s...ayproducts.asp
http://www.cherrybomb.com/products/
http://www.flowmastermufflers.com/se...t=Search%20Now
Old 01-25-2010, 12:31 PM
canuckboy's Avatar
Trim Level: None
Rep:114
Check out this site supporter also....
http://www.bmcspeedshop.com/category_s/221.htm
Old 03-14-2010, 10:08 PM
kroll's Avatar
kroll kroll is offline
Vehicle: 04 Ram 1500 crew cab 5.7
Color: bule
kroll is on a distinguished road
i just went to the local muffler shop and they welded on a 12 inch vortec exhaust and it sounded nice for a fair price
Old 04-15-2010, 11:35 AM
GarGon GarGon is offline
Vehicle: 1999 Dogde Ram Pick Up V6 3.9
Color: gray
GarGon is on a distinguished road
Start giving me problems ram pick up my 99 V6 and sometimes when I turn cold out immediately, I have to speed it up several times to stay on, it seems as if no air gets into will be that the injectors are dirty, some suggestion thanks
Old 05-07-2010, 06:14 PM
canuckboy's Avatar
Trim Level: None
Rep:114
Hey there,
Well I put a cherry bomb on my truck pretty much the same size and diameter as stock which is 3". Its a straight swap and it sounds excellent.
As for your problem im sorry I have not been on the site for awhile but you might want to start with the basic maintenance things like plugs, wires, cap , rotor and go from there. Try some throttle body cleaner and maybe some fuel additives ????
Thanks!
Old 06-03-2016, 12:41 AM
Simon930 Simon930 is offline
Vehicle: 2015 ram 1500 express
Simon930 is on a distinguished road
Looks great
