Old 01-24-2010, 01:17 AM
foxcrazy90's Avatar
foxcrazy90 foxcrazy90 is offline
Vehicle: 2008 dodge ram 1500
Color: electric blue pearlcoat
Rep:584
foxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to allfoxcrazy90 is a name known to all
not only is it cheap,its better than cheap , its free!!!!!!!
NEIL KELLEY
2008 ram 1500 bighorn 4x4
2 1/2 level lift--hella 500ff grill lights--17x9 centerline grizzly-305-70-17 nitto terra grapplers--front air valance removed--tinted windows--custom audio system clarion vz401 head unit--pioneer 4channel amp and class D mono amp--memphis mclass door speakers--clarion dash speakers--kicker subs
Old 01-24-2010, 01:19 AM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Yep, I have to see pictures too! Lol.
Old 01-24-2010, 01:20 AM
Rep:4072
Originally Posted by Toms Blue Ram 1500 View Post
Nice bones, now, how 'bout them pics????
Old 01-24-2010, 01:59 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I highly doubt that removing a wire will "add" power.
Old 01-24-2010, 02:52 AM
Interesting...I have never heard of a feature or a mod like this.
Old 01-24-2010, 09:01 AM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
It's only on the 2003 Hemi trucks. Apparently Dodge was in such a rush to get them into production (this is just what I read somewhere) that they had two control modules, one for the engine, and one for the transmission. This wire controls how much fuel is delivered in first gear. The Hemi is restricted in first gear to reduce tire spin, then once you get into second gear it's all go as normal. By unplugging this the truck doesn't know it is in first gear so boom! Fuel delivered all the way through the power band.
By 2004 Dodge had enough R&R done to produce the ECM/TCM into a one piece unit. Those computers work a bit different, so simply unplugging a wire on them won't yield these benefits.
Again, this is just what I've read in various places from people that had done this modification and none of them reported any ill effects to their motor or transmission.
Old 01-24-2010, 10:13 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Thanks Chithead.I have tried to pull your link/pic over here with no luck. How do you do that anyway?
Old 01-24-2010, 10:36 AM
chithead's Avatar
Rep:2078
Here ya go:
Take off the 1B cover and you will see the Yellow and green wire going into the plug. With a small socket set loosen the bolt in the center and pull the plug away from the Computer. Locate the correct side where the Yellow and green stripe wire is and then Pry the RED retainer out and using a jewelers flathead screwdriver and push the wire out the back and pull the wire completely out.
Old 01-24-2010, 10:45 AM
Interesting . I wonder how it will effect emissions on test day ?
Old 01-24-2010, 11:01 AM
bones64's Avatar
Rep:659
Imgoing to hook it up to a switch in the cab. Giving me the opportunitty to turn it on or off. As for test day i will make sure its on. Chithead thanks for bringing that over. How did you do it?
