Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > LD RAM - Ram 1500 Forum > LD RAM - General Discussion
LD RAM - General Discussion RAM 1500 General Chat. Please post your tech questions in the HELP Zone!
Place your Ad Here!
Old 01-24-2010, 11:19 AM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Question Engine cleaning with a CAI
Hey all. I was curious to know when you want to clean your engine and compartmet what is the best way when you have CAI. Do you take it off and put something over the trottle body? Like to know. Not sure whats the best not always the easiest way.Sorry if this has been brought up already.
Old 01-24-2010, 11:59 AM
hauser775's Avatar
hauser775 hauser775 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: SLT Laramie
Rep:67
hauser775 will become famous soon enough
Just avoid the CAI when you are cleaning the engine. If you are worried about it just put a plastic bag over the filter with some elastics, that should keep any liquids from getting into the filter or intake.
Old 01-24-2010, 12:06 PM
bones64's Avatar
Rep:659
Thanks . That was what i was thinking. Water..........a big no no no no.I wasnt sure to take it completely off. Mine is easy...back off the clamp at the throttle body and it comes off in one piece.Homemade CAI. Thanks.
Old 01-24-2010, 12:14 PM
careyjs careyjs is offline
Vehicle: 2010 Ram
Color: Inferno Red
Rep:33
careyjs is on a distinguished road
If it were me, I would pull the whole unit off. Not sure if your CAI has the shroud around it, but for a really good clean, I would pull it off.
Old 01-24-2010, 06:13 PM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:435
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
Fo me, when I decide to clean the engine, I'd rather cover the cai and carefully clean than to have to remove that setup. Took me long enough to install that sucker. If you're engine needs an intensive cleaning, then I guess it makes sense to remove it.
Old 01-24-2010, 06:27 PM
You could do either. If you need to clean the filter and the engine, I'd pull the filter, clean it and let it dry while you tackle the engine bay.
Just cover the intake tube to keep water and chemicals outta the intake.
Old 01-24-2010, 06:39 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
Keep in mind the CAI is not all you should worry about when your cleaning your engine. You'll want to cover your alternator and spark plug housings. Since you have the hemi, I believe you have 16 of them to cover up Lol.
You don't have to necessairly cover them... Just don't be too liberal with the water on those areas.
Old 01-24-2010, 06:50 PM
bones64's Avatar
Rep:659
Lots of good tips thanks all. I will keep that in mind.
Old 01-24-2010, 07:09 PM
Resident Technician
Rep:1915
The biggest thing to remember is not to spray high pressure water on anything. The spray from a garden hose should be plenty.
Old 01-24-2010, 07:25 PM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
Just cleaned my engine bay this afternoon. Didn't cover anything but only used low pressure water (hose). Haven't started it yet but I doubt there will be any problem. You'll hear about it if there is!
